Need help getting wiper arms off. - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-17-2012, 12:01 PM   #1
Flycaster
My Ride: '05 Z4 2.5, '13 ATS
Even though I have done quite a few mods on both my cars, getting the wipers off my 2002 E46 has me stumped. I have read both of these good DIYs (http://www.e46fanatics.com/forum/sho...d.php?t=373451 and http://forums.bimmerforums.com/forum...ht=microfilter). Here are the tips on how to remove the wipers once the bolt nut is taken off. These are taken from posts on e46Fanatics and all say you don't have to use a gear puller (I don't have one). Also, I have jiggled, lifted, pressed and nothing works to get the pressure nut to pop.
#11..."Under the nut is an aluminum cone-shaped serrated "thing" that is called a "washer" with xxx in.lbs stamped on it. It's ok to use gear puller but you don't have to -- just push the arm down flat and pick-wiggle the cone-shaped thing up, and then push down and up again on the arm"
What does he men by pick wiggle?
#15..."helpful to raise your wiper arm a little at the spring-loaded connection point, as the spring action tends to put the wiper arm in a bit of a bind with the shaft that it's attached to."
Isn't this just the opposite of flattening the arm? I've raise the arm slightly and jiggled and nothing happens
#17..."to pull that metal screw the trick was to push the wiper down and it flexes on its own start jiggling it."
I've pushed down on the wiper and jiggled and nothing happens
#19..."There is an easy way to take off the wiper arms without any tools. Just press down on the spring on the wiper arms and the bolt configuration and it comes up slowly. So in short, take off the cap, use a 15mm to take off the bolt, then press on the spring and the configuration comes up."
By saying pressing down on the spring, does he mean press down on the part of the arm that has the spring so that you attempt to flatten the wiper and that this will raise to whole pressure nut/wiper assembly. I think he does, but when I do it nothing happens.
Flycaster is offline   Reply With Quote
Old 02-18-2012, 02:45 AM   #2
Arty
My Ride: 1999 328i
Have you used some plusgas on the spindle to loosen the stuck on arm?
Arty is offline   Reply With Quote
Old 02-18-2012, 03:15 AM   #3
Bimmer4Lyfe
Location: 129 West 81st St. 5A, New York, New York 10024
My Ride: 02 325i
Push down on the arm towards the glass then gently tap the main bolt with a small ball peen hammer. You should see some results.
Bimmer4Lyfe is offline   Reply With Quote
Old 02-18-2012, 08:14 AM   #4
Flycaster
Thanks, will try later this weekend.
I have sprayed DW40 on the bolt/pressure nut assembly, but haven't tried to loosen the wipers yet. Also, on another forum, they suggested that while pressing down on the arm, that I should also move the arm upwards as if it is wiping.
Old 02-18-2012, 01:14 PM   #5
G-Hots
My Ride: ///M3 & 328ci
Send a message via AIM to G-Hots Send a message via MSN to G-Hots
major PITA. try to wiggle it while applying pressure on the bolt
G-Hots is offline   Reply With Quote
Old 02-20-2012, 10:26 AM   #6
Flycaster
Thank you and success. After having failed on the first try, I sprayed on some DW40 after the nuts was removed and came back again two days later. Removed the nut and tapped on the bolt with a solid rubber mallet, pressed down on the spring section of the arm while jiggling upwards, and up pops the silver pressure nut. Don't know if the DW40 helped or if was the pressing down while jiggling or a combination of both, but I am now a happy camper.
The only other sticky part was that although the cover was easily pulled out from its clips, it got hung up on the middle bolt and I had to remove just the filter housing cover (easy enough) to get it off.
Old 02-20-2012, 12:50 PM   #7
AMKing
Banned
My Ride: BMW
I think you mean you used "WD-40" not "DW40". Sorry, I'm real anal and OCD.
AMKing is offline   Reply With Quote
Old 02-20-2012, 02:05 PM   #8
Flycaster
Thanks. You're not the only one
Old 05-21-2013, 02:03 PM   #9
Kurt597
My Ride: 330xi
Is the spring section difficult to get back on? I'm about to attempt this so I'd like to be able to put my car back together when done.
Kurt597 is offline   Reply With Quote
Old 05-21-2013, 03:26 PM   #10
Flycaster
Don't quite remember how it all went back together, but I do recall that the info here was right on and putting things together was no problem. Just follow the info. Good luck.
Old 05-21-2013, 04:10 PM   #11
Kurt597
My Ride: 330xi
Great thank you.
