Old 04-21-2013, 10:41 AM   #1
jwbeck17
My Ride: 2005 330xi
Possible Oil Leak
I was under my 2005 330xi for some transmission work and have noticed a little oil at the base of the engine. I have replaced the valve cover gasket and the oil filter housing gasket. The vanos area looks clean. Just looks like I am collecting a few drops at the bottom. Got a pic:
Also a few drops around the oil plug:
And a drop coming off of a bolt where it meets the tranny.
Any thoughts on where to check for these?
jwbeck17 is offline   Reply With Quote
Old 04-22-2013, 05:50 PM   #2
latitude39
My Ride: 2002 325xi (163k)
Originally Posted by jwbeck17 View Post
... noticed a little oil at the base of the engine. I have replaced the valve cover gasket and the oil filter housing gasket. The vanos area looks clean. Just looks like I am collecting a few drops at the bottom.
Maybe it's the radial seal where front driveshaft plugs into the mounting pedestal. It's an eight-dollar seal that requires the axle half-shaft to be removed.
It's also possible that this is leftover oil from before you VCG job.
latitude39 is offline   Reply With Quote
Old 04-22-2013, 09:38 PM   #3
jwbeck17
My Ride: 2005 330xi
Possible Oil Leak
Thanks! I'll take a look at that driveshaft seal. I thought it could be residual oil from the vcg/ofhg replacement, but I had cleaned the area previously. However, the scent of burning oil is gone from prior to the gasket repairs, and there are no signs of leaks from the top.
