Old 04-21-2013, 12:23 PM   #1
BigDRick323
My Ride: 2000 323i
Vert Seats in Sedan: swap rails or issues?
I cannot find a DIY on how to fit Vert seats in a sedan, help!?
Old 04-29-2013, 09:10 PM   #2
BigDRick323
My Ride: 2000 323i
Seat Belt Removal DIY
Ok changing up ideas, can i remove the seat belts from the b-pillars without causing any problems? Use the seatbelts from these vert seats.
Sent from my LG-MS870 using BimmerApp mobile app
Old 04-30-2013, 12:06 PM   #3
BigDRick323
My Ride: 2000 323i
Re: Permanent Seat Belt Removal, cause any problems?
Bump
Old 05-01-2013, 03:55 PM   #4
Ballistic325
My Ride: slow and steady
Shouldn't be a problem as the SRS still sees a seatbelt, pretensioner etc. only issue might be to see that the under seat electrical connectors all fit.
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 05-11-2013, 11:42 AM   #5
BigDRick323
My Ride: 2000 323i
Electrical connectors fit, but there is a problem. Seat rails are different widths.....uhoh.
Old 05-11-2013, 09:59 PM   #6
Ballistic325
Can't swap them out with originals?
I can help with
* RTABs
Old 05-11-2013, 10:04 PM   #7
BigDRick323
My Ride: 2000 323i
Don't think it will make a difference, the width difference is like 11/2.Attachment 505081Attachment 505082Attachment 505083Attachment 505084Click image for larger version
ID:	505177   Click image for larger version
ID:	505178   Click image for larger version
ID:	505179   Click image for larger version
Old 08-25-2013, 03:00 PM   #8
BigDRick323
My Ride: 2000 323i
Re: Vert Seats in Sedan: swap rails or issues?
Didn't happen, so i have some e46 vert m seats available, anyone interested?
Old 08-25-2013, 03:12 PM   #9
Snik
Snik's Avatar
My Ride: IR M3 Vert.
so why would you even want vert seats in a sedan?
Do you ride a sportbike?
Old 08-25-2013, 03:13 PM   #10
BigDRick323
My Ride: 2000 323i
I got a good deal on them, and they were M seats....
Old 08-25-2013, 03:17 PM   #11
Snik
Snik's Avatar
mmmm...i hear you... my set is in great condition, otherwise id likely buy em.
kinda shocked they dont fit, as coupe to sedan seems to be a direct swap..but the integrated seatbelt probably needed the wider rails.
I say keep em, and try to score some vert seat rails, id imagine the mounting points in the floor are already pre drilled if not shared, and just need to be popped.
Old 08-25-2013, 03:26 PM   #12
BigDRick323
My Ride: 2000 323i
The problem is the mount points, they are not the same, would have to custom drill mount points, not worth it.
Old 08-25-2013, 03:40 PM   #13
Snik
Snik's Avatar
id bet money theyre already pre stamped... i really doubt its a whole different piece, just needs to be popped out.
Old 08-25-2013, 03:56 PM   #14
BigDRick323
My Ride: 2000 323i
I already found a good deal on some sport seats that fit the sedan that were in better shape, so I'm just going to try and sell these now.
Old 08-25-2013, 04:51 PM   #15
Snik
Snik's Avatar
Cool
