Go Back   E46Fanatics > Everything Else > The Off-Topic > Gun Talk
Gun Talk
Are you a gun fanatic as well? If so, you'll want to talk to other owners about what you own in this forum.
Old 04-21-2013, 09:01 PM   #1
Rush4theYehO
My Ride: XI fts(now)
Problem with my Glock 19
Guys, went to the shooting range today and had an unexplained malfunction pop up with my Gen3 G19. The slide locks back mid-magazine. As if the mag were empty, but you tilt the gun upwards and you clearly still see a live round ready to be fed. Now before you tell me I am hitting the slide release with my thumb....
1. I am lefty. My index/shooting finger sits far below.
2. The slide lock is the stock unit that the gun comes with
3. All three shooters with me experienced the same thing - they are all right handed.
4. I shot one handed, limp wristed, overgripped the pistol in order to duplicate the malfunction, and it didn't matter what I tried, it did it almost every time. 10 rds loaded, the slide lock happened about 7/10 rounds.
Any guesses what is causing this?
Rush4theYehO is offline   Reply With Quote
Old 04-21-2013, 09:33 PM   #2
JonJon
Tinfoilhatatarian
JonJon's Avatar
My Ride: .
Send a message via AIM to JonJon
Try different mag?
Mag spring or slide lock spring?
Inspect the lock to make sure its seating well.
Might need to have Glock file it down some.
New gun? Just start happening? How many rounds through it?
JonJon is offline   Reply With Quote
Old 04-21-2013, 09:38 PM   #3
Rush4theYehO
Originally Posted by JonJon View Post
Try different mag?
I'm thinking the latter. I brought 5 different mags (3 of which are new). Didn't make a difference which one I loaded up.
Old 04-21-2013, 09:40 PM   #4
JonJon
Tinfoilhatatarian
JonJon's Avatar
My Ride: .
Yea, the mag follower is what should be pressing on it and causing lockup when the mag is empty. Gotta be the lock spring
Old 04-22-2013, 02:27 AM   #5
Reedo302
Reedo302's Avatar
My Ride: F30 328i M Sport
Supposing that you have eliminated shooter error with physically pushing the stop up manually on accident, the next step would be to inspect
Field strip your gun. Insert loaded mags and see if any of them manipulate the slide stop lever. If not that, then unload and lift up on the slide stop lever, then release it. It should snap downward quickly and hard. If you remove the slide and the lever lifts up on its own, the gun was assembled incorrectly and the spring for the lever likely got caught behind the locking block pin. If it drops down slowly or without a lot of force, you have a bad lever/spring and it needs to be replaced.
Mechanically, this issue is most commonly caused by improper assembly of the frame and catching the spring behind the locking block pin, instead of under it. Secondary to this is a bad lever.
DINAN3 F30 328i M Sport
DinanTronics Stage 1
Dinan Free Flow Black Tip Stainless Exhaust
Dinan Lowering Springs and Bumpstops
Dinan 20" Black Performance Wheels
Gunfighter Training Development and Evaluation
AR15/AR10 Armorer/Advanced Armorer
Glock Armorer
Gunfighter Training YouTube Channel
Reedo302 is offline   Reply With Quote
Old 04-22-2013, 08:59 AM   #6
GasKing
My Ride: 1990 Yugo GVC
Good job. You fvcked up a glock. Id be proud.
GasKing is offline   Reply With Quote
Old 04-22-2013, 05:19 PM   #7
Rush4theYehO
Thanks guys. 10k rounds and this is my first parts breakage. I grabbed the pistol to detail strip, dropped the mag, emptied the gun but hadn't pulled the trigger yet. I noticed it was rattling on the inside. Stripped the gun down, and just like you said Reedo - the slide stop is definitely broken. Doesn't work at all.
Is the slide stop lever the only thing I need to swap, or anything else needed?
Old 04-22-2013, 05:23 PM   #8
Reedo302
Reedo302's Avatar
No, just that. Quick easy fix. You could get Glock to replace it for free, but it might be faster to spend $10 and buy a new one on your own. Any Glock stocking dealer that has certified armorer service may be able to replace it under warranty as well.
Glock Armorer
Old 04-22-2013, 05:29 PM   #9
Rush4theYehO
I'll just fix it. I've detail stripped a glock plenty, fairly easy. The fact that I can break down a glock with my 8 fingers on my three hands is a testament to my handiness.
Old 04-22-2013, 08:54 PM   #10
shwagon
My Ride: 325it 5-speed
A glock broke?!?!?!?!
What an unending cavalcade of rampant virgin Mom's-basement-dwelling douchebaggery... Wow.
My Gun Builds: AR-15, GSG-522-SD, Saiga 308
shwagon is offline   Reply With Quote
Old 04-24-2013, 05:27 PM   #11
GasKing
Awesome. You have my respect, I have about 4500-5000 through one of my 19's. 10k+ is really a testament to how sturdy a Glock is. A guy on my local forum had a spring fly out of his Taurus with only 300 rounds through it.
Old 04-24-2013, 05:55 PM   #12
GlockMan
GlockMan's Avatar
My Ride: Suburban LT 4x4
I still have my first Glock 19 (second gen) that is over 15 years old and probably has atleast 25k rounds through it. Not a single issue.
!!! ROLL TIDE ROLL !!!
National Champs: 1925, 1926, 1930, 1934, 1941, 1961, 1964, 1965, 1973, 1978, 1979, 1992, 2009, 2011, 2012, 2015, 2017?
Ranting about Panny plasmas, Canon cameras, Glocks, BlueNile, and HDMI on a BMW board since 2005.
2016 Honda Accord Sedan V6 Touring (wife)
2007 Chevy Suburban LT 4x4 with Nav/Bose/DVD
1968 Ford Mustang with Polk/ADS (my first car)
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
GlockMan is offline   Reply With Quote
Old 04-24-2013, 05:59 PM   #13
GasKing
Thats awesome, post pics of the internals when you get a chance.
Old 04-24-2013, 06:40 PM   #14
JonJon
Tinfoilhatatarian
JonJon's Avatar
My Ride: .
Besides being ugly
Lol
Old 04-24-2013, 06:42 PM   #15
XKxRome0ox
Black and Proud
My Ride: RIP e46/'16 328i
Besides being ugly
Lol
[bimmerapp]
2016 BMW 328i 6MT/M Sport Package/Track Handling Package/BMW M Performance Exhaust/Injen CAI
XKxRome0ox is offline   Reply With Quote
Old 04-24-2013, 07:33 PM   #16
GlockMan
GlockMan's Avatar
I am dead serious when I tell you it looks like a new one (third generation) with 1000 rounds threw it.
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
Old 04-25-2013, 06:29 AM   #17
nightrunner20
My Ride: will eat your dust
Send a message via AIM to nightrunner20
WOW 1 in a million. never had any of my 3 glocks malfunction on me yet...besides a bad .357 sig mag (weak spring) in my g27.
nightrunner20 is offline   Reply With Quote
Old 04-25-2013, 03:51 PM   #18
Reedo302
Reedo302's Avatar
I did annual inspections on the department Glocks back in February and found a broken locking block. 1 out of 40 isn't bad. I replace probably 12 mag springs a year, along with a half dozen recoil springs, and a couple locking block pins and slide stop levers. Not bad though, when you consider that I am primarily doing preventative proactive maintenance. Any hint of a problem and I just replace the part. Before I took it over, there were a lot more problems, though primarily from the guys running weaponlights.
Glock Armorer
