Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Parting Out
Parting Out
Parting out your car? Post your entire list of BMW parts for sale in one forum. Single items should be posted in one of the other classified forums.
Old 04-22-2013, 03:15 PM   #1
BoostinGST
My Ride: 99 323i & 00 323i
Parting out 2000 323i.
I bought a 99 body that needed a motor so thats not for sale but anything and everything else is available. the car ran off the road and flipped in the ditch so most of the body is trashed. My prices are lower than what I can sell it for on ebay, just figured I'd list them here first. I'm located on the MS Gulf Coast if anyone wants to pick up parts. if theres anything not listed I most likely have it.
Automatic Transmission $750
Rear Diff $200 SOLD
ECU KEY EWS $250.00
Throttle Body $150.00
driveshaft $150.00
CD Player $100.00
exhaust manifolds $200.00
flywheel $150.00
engine wiring harness $100.00 SOLD
sunroof $200.00
steering wheel airbag $100.00
Battery Cable, airbag fix $100.00
radiator fan $100.00 SOLD
rack and pinion $100.00
dsc module $100.00 SOLD
heater core blower motor $100.00
abs module $125.00 SOLD
fuel charcoal canister $100.00
seat tracks $50.00
neutral switch $100.00
intake manifold $100.00
door airbags $150.00
power steering pump $75.00 SOLD
cross member $75.00
rear subframe $50.00
mass air sensor $75.00 SOLD
alternator $50.00 SOLD
ac compressor $50.00
fuel rail $75.00
window regulators w/ motor $150.00
fan blade w/ clutch $50.00
hood latch/lock/cable $50.00
door handles $150.00
power steering hose $50.00
seat belt latch tensioners $100.00
trunk lid handle/lights $50.00
valve cover $50.00 SOLD
gas pedal $50.00 SOLD
wheel hubs(front) $75.00
factory jack $40.00 SOLD
third brake light $40.00
oil pump $30.00
heater control valve $30.00
column switch $30.00
Trunk latch $30.00
egr valve $30.00
fuel pressure regulator $30.00 SOLD
coil pack $25.00
antenna amp $30.00
side markers $50.00
Rear Spindles $200.00 SOLD
Radio Amp $125.00
rear springs $125.00
headlight $200.00 SOLD
rear axles $100.00 SOLD
engine shield $100.00
bumper rebar $100.00 SOLD
comfort control mod $100.00
air box $100.00
smog pump $100.00 SOLD
steering angle sensor $100.00
vanos unit $100.00
alarm motion sensor $100.00 SOLD
TCU $100.00 SOLD
mirror $100.00
glove box $75.00
oil pan $100.00
fuel pump and sender $75.00 SOLD
wiper assembly $75.00 SOLD
intake adjuster valve $50.00
front calipers $50.00
shifter $75.00
trunk toolkit $50.00
trans oil cooler $50.00
ac controls $50.00
pusher fan regulator $50.00
headlight switch $50.00
post cat o2 sensors $50.00
rear carpet $40.00 SOLD
lower timing cover $50.00
rear shocks $50.00
sway bar $40.00
oil filter housing $40.00
engine cover $50.00
wiper motor cover $50.00
fan shroud $35.00
tail lights $250.00
cam position sensor $40.00
trunk liner $30.00
ac vents $35.00
airbag sensor $40.00
idle air control valve $30.00
spare tire cover $30.00
owners manual $30.00
intake manifold radiator tube $60.00
trunk lid $200.00
rear deck $100.00
DSC ABS COMPRESSOR PUMP $40
Last edited by BoostinGST; 02-03-2014 at 06:03 PM. Reason: MARKED SOME THINGS AS SOLD
BoostinGST is offline   Reply With Quote
Old 04-22-2013, 03:17 PM   #2
2000beamer
My Ride: 2000 323i
Color of the interior? I'd be interested in a grey center armrest
[/SIGPIC]
2000beamer is offline   Reply With Quote
Old 04-22-2013, 03:32 PM   #3
BoostinGST
My number is (228)324-5113 if anyone has any questions just text. when I'm not at work or school im pretty busy so it might be a few hours before I can respond...
Old 04-25-2013, 10:10 AM   #4
BoostinGST
Tan interior, Alpine white exterior...
Old 04-28-2013, 05:47 PM   #5
Daltondak
My Ride: 00 323i, 92 300zx tt
I need the water gutter like, hard black trim piece that goes over and around the rear quarter window on the drivers side????? Let me know, pm or email me daltondak@yahoo.com
Daltondak is offline   Reply With Quote
Old 04-30-2013, 04:32 AM   #6
BoostinGST
still didnt get the picture... anyone else that has asked for parts should get a response later today with pictures or info. it rained yesterday so I didnt get to check on anything
Old 04-30-2013, 05:11 AM   #7
BBBoy323i
My Ride: 01' 325ci
PM'd
BBBoy323i is offline   Reply With Quote
Old 04-30-2013, 06:03 AM   #8
BoostinGST
Originally Posted by BBBoy323i View Post
PM'd
Replied.
Old 05-01-2013, 05:51 AM   #9
Daltondak
Sorry it took so long to get you some pictures. Here is the part I'm missing on the driver side and I took a picture of the other side so you could see whats missing. I need the three clips too. Thanks
ID:	503316   Click image for larger version
Old 05-01-2013, 11:17 AM   #10
AlexTe46
My Ride: 2001>325i>sedan
How much for the bee sting antenna?
IMG_0010/IMG_0274
AlexTe46 is offline   Reply With Quote
Old 05-01-2013, 11:52 AM   #11
BoostinGST
The back door is kinda caved in/bent. also that piece seems to be one piece on mine.
Old 05-01-2013, 11:57 AM   #12
BoostinGST
Let me make sure the antenna isn't broke $20 shipped if it is good though
Old 05-01-2013, 01:09 PM   #13
AlexTe46
Ok let me know I would need the whole thing
IMG_0010/IMG_0274
Old 05-01-2013, 02:20 PM   #14
BoostinGST
its good, I just pulled the antenna off, are you saying you need the cable too?
Old 05-02-2013, 12:16 PM   #15
AlexTe46
No I don't need the cable just the antenna and the base
IMG_0010/IMG_0274
Old 05-02-2013, 02:24 PM   #16
BoostinGST
PM'd
Old 05-07-2013, 05:30 PM   #17
BBBoy323i
My Ride: 01' 325ci
Hey, so any details on the center switch panel? Thanks
Old 05-07-2013, 10:45 PM   #18
Gabbs
My Ride: 323i
Do you have the driver side mirror cover ?
Gabbs is offline   Reply With Quote
Old 05-08-2013, 11:03 PM   #19
bxny1984
My Ride: 2000 323i
I PMed you
bxny1984 is offline   Reply With Quote
Old 05-09-2013, 10:53 AM   #20
turbotalon1g
My Ride: '02 330i
I need the mounting bracket for the ET if its still good?
turbotalon1g is offline   Reply With Quote
