Sponsored by The Tire Rack
Old 04-23-2013, 01:03 PM   #1
adaseb
My Ride: 2002 BMW 320i
Got outer tire wear only on one side
My situation is similar to the photo.
However its only on the drivers side, not on the passangers.
Got an alignment about a year ago.
Anyone know what the issue can be? Just get another alignment? Or can it be some suspension issues since its on one side?
adaseb is offline   Reply With Quote
Old 04-23-2013, 01:07 PM   #2
haurelio
My Ride: 2001 bmw 325i
it could be struts ,camber or RTABs
Contact me if you need to unlock your phone.
Also can code your car
Old 04-23-2013, 01:11 PM   #3
adaseb
RTAB? this is only in the front
Old 04-23-2013, 01:51 PM   #4
SpoiledBrat
My Ride: 330Ci zhp
First step is always check tire pressure, but that wouldn't explain why it's only on the outer side.
SpoiledBrat is offline   Reply With Quote
Old 04-23-2013, 11:32 PM   #5
2003 325i
My Ride: '03 Orient Blue 325i
Looks like it could be a camber issue, tread depth looks to progress across the tire.
Originally Posted by MTA330ci View Post
Does anyone have a recommendation on which is the best high performance valve stems?
Old 04-24-2013, 11:55 AM   #6
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Take your car to a suspension shop, have them inspect all the bushings, and if they don't need replacing, have them align everything.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 04-24-2013, 05:07 PM   #7
03BIMMERM3
My Ride: 2003 BMW M3
Its that the inside or outside of the tire? Car lowered?
Sent from my myTouch_4G_Slide using Bimmer App
03BIMMERM3 is offline   Reply With Quote
Old 04-24-2013, 06:06 PM   #8
adaseb
Outside of the tire. Away from the center of the car..
Not lowered. Stock
Old 04-25-2013, 06:43 PM   #9
03BIMMERM3
If that was ur rear, I would say stop tryin to burn out lol if its your front, id tell you u to change out ur front bushings, but id get an alignment first, and if it continues..then worry bout it
Old 05-03-2013, 04:05 PM   #10
adaseb
The bushings and control arms were changed already.
Is this considered camber wear or toe wear?
Old 05-03-2013, 05:57 PM   #11
NetoE46
My Ride: E46-325ci
your tire is toe'd in...get an alignment
NetoE46 is offline   Reply With Quote
