Old 04-23-2013, 03:45 PM   #1
e46ornothing
My Ride: 2005 BMW 325i
What rpm u show at 80?
Hey guys I'm pretty sure this is where this thread go but if not sorry.
I'm trying to see if my car is running ok.. I have a feeling that my rpms are running high.
Mainly at 80 mph, I'm showing about 3500-4000 rpms, is that right? It seems to high for me but I'm not sure, which is why im asking.
Any help would be appreciated!
e46ornothing is offline   Reply With Quote
Old 04-23-2013, 04:06 PM   #2
bmwTuner1
My Ride: Bmw, 330ci
Those are really high rpm's. I'm assuming you haven't changed your diff. When I changed the diff on my 330ci (manual) from a 2.93 to a 3.07 the rpm's at 80mph changed from appx 2600 to 2900.
Is your car auto? Do you know if its changing from 4th gear into 5th?
Photobucket
bmwTuner1 is offline   Reply With Quote
Old 04-23-2013, 04:10 PM   #3
e46ornothing
Yea I thought they were high. My car is a 05 325i 5 speed Manual. And it shows this in 5 gear while cruisin at 80 on the fwy hahah :/
Old 04-23-2013, 04:10 PM   #4
2000beamer
My Ride: 2000 323i
Approximately 2,700
[/SIGPIC]
2000beamer is offline   Reply With Quote
Old 04-23-2013, 04:20 PM   #5
e46ornothing
So for sure I see my rpms are higher than there supposed to be at.
Anyone know how to figure out why they are? Or how to fix the problem?
Old 04-23-2013, 05:14 PM   #6
lszlszx
My Ride: 1.8T, XC70
Originally Posted by 2000beamer View Post
Approximately 2,700
Is this for 5, or 6 speed?
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 04-23-2013, 05:16 PM   #7
2000beamer
My Ride: 2000 323i
5 speed auto. I really never put it in shifting mode, the car knows when to shift better than I do.
[/SIGPIC]
Old 04-23-2013, 05:28 PM   #8
lszlszx
My Ride: 1.8T, XC70
OK, that makes sense, because sticks are supposed to have shorter gearing, like 2800 rpm @ 70 mph. Mine is auto also 2500 rpm @ 70 mph.
I love the ratios on the automatic.
Old 04-23-2013, 05:31 PM   #9
lszlszx
My Ride: 1.8T, XC70
Well, I see 3 possibilities:
1. the clutch is slipping
2. your tachometer is inaccurate
3. you're not driving in 5th gear
Old 04-23-2013, 09:01 PM   #10
e46ornothing
1. What is a symptom of my clutch slipping?
2. Could be a possibility since I installed m3 gauges from bimmian lol
3. Ur saying I'm driving in 4th? Lol trust me I'm in 5 haha
Old 04-23-2013, 10:41 PM   #11
lszlszx
My Ride: 1.8T, XC70
When the clutch slips engine revs will be higher than should be at a given speed, but if it slipped that much, you would smell it. It must be the cluster that you swapped in, did you follow a DIY?
Old 04-23-2013, 10:42 PM   #12
lcoleman
My Ride: '79 Massey Ferguson
That is normal for a 5 speed 325i. Sucks, but it is what it is.
Old 04-23-2013, 10:54 PM   #13
e46ornothing
Yea I don't smell anything. I'm starting to think its the cluster swap, and yea even followed what bimmian said to do lol.
Old 04-23-2013, 10:55 PM   #14
e46ornothing
Why do u say that? Are ur rpms this high as well?
Old 04-23-2013, 11:59 PM   #15
bmwTuner1
My Ride: Bmw, 330ci
Wait, you did a cluster swap? We're your rpm's lower before you did that?
Photobucket
Old 04-24-2013, 12:22 AM   #16
e46ornothing
No not an actual cluster swap lol. I bought the gauges that bimmian sells.. There the m3 style ones.. That's wat I meant
Old 04-24-2013, 12:38 AM   #17
northbranchroad
My Ride: 2002 325i bmw
Around 3500 is definitely normal for 80 mph on a 5 speed e46 325i
northbranchroad is offline   Reply With Quote
Old 04-24-2013, 02:41 PM   #18
TerraPhantm
My Ride: M3 & ZHP
Because 325s come with pretty short ratio diffs.
Old 04-26-2013, 12:34 PM   #19
j_block
My Ride: 2003 325i
Re: What rpm u show at 80?
I think I'm around 3700-3800rpm at 80mph in my 325 5 speed. But I also have 3.46 gears
j_block is offline   Reply With Quote
Old 04-27-2013, 02:26 PM   #20
NyC35AV
My Ride: 99' 323i ZSP/S52 E34
I'm showing 3300 on my 5 speed 323i. I did a diff flush last week and for the life of me couldn't find a tag with the ratio! I do find myself trying to shift into another gear that's not there (6th gear) : (
NyC35AV is offline   Reply With Quote
