///M3 Forum
Old 04-24-2013, 08:42 AM   #1
ctf85
My Ride: 2004 BMW M3
SMG Bleeding topic !!
Hi guys,
So I discovered a leak in my SMG system through the hose and have had it replaced through an independent mechanic.
Apparently I have to bleed the SMG system now to make sure there are no air in the system and only a BMW dealership can do this?
First of all does it need to be bled and can ONLY a BMW dealership can do this?
Can anybody shed some light please?
Cheers
ctf85 is offline   Reply With Quote
Old 04-24-2013, 09:20 AM   #2
choxor
My Ride: JDM
Originally Posted by ctf85 View Post
Hi guys,
Cheers
You need INPA or a GT1. Take it to a good indy.
Old 04-26-2013, 03:26 PM   #3
mooninite
My Ride: M3, X5
Takes about 15 minutes to do, so it should be a half-hour labor charge. If you need it ASAP then find a dealer/indy. If you can wait you can order the software off eBay.
mooninite is offline   Reply With Quote
