///M3 Forum
Old 04-24-2013, 02:32 PM   #1
M3 boyzky
My Ride: 2006 M3
Wheel spacers for ZCP stock wheels.
Hi y'all!
I'm thinking of using wheel spacers and not what size to get and safe from rubbing. As stated I have stock ZCP wheels (19 x 8" fronts and 19 x 9.5 rears) with 245 tires front and 275 rears. I just wanted wider stance and fill fender gaps. I just want spacer sizes that will not rub the tires especially when I drop the car down by about 1" later on. I would appreciate all you guys recommendations. Thanks!
M3 boyzky is offline   Reply With Quote
Old 04-24-2013, 04:40 PM   #2
03BIMMERM3
My Ride: 2003 BMW M3
I have 12's on my frnt and 15s on the rear..had to flare out my fenders in the rear..id say 12mm all around should be good
Sent from my myTouch_4G_Slide using Bimmer App
03BIMMERM3 is offline   Reply With Quote
Old 04-24-2013, 04:57 PM   #3
Firstboost
My Ride: 2006 Tiag ZCP
Under hard turning you will rub in the rear with 12mm's and ZCP's.
I'm running 12 in the rear and 15 up front with no issues.. I should've gone 18MM up front though.
Firstboost is offline   Reply With Quote
Old 04-24-2013, 05:11 PM   #4
e46dinan
My Ride: E46 M3, E53 4.6is
15mm front 12mm rear.
e46dinan is offline   Reply With Quote
Old 04-24-2013, 08:11 PM   #5
M3 boyzky
My Ride: 2006 M3
What do you guys think about 12mm fronts and 10mm rears? Would these be safe all around?
Old 04-25-2013, 02:54 AM   #6
sakumaxp
My Ride: 02 M3 convertible
I'm dropped on KW V2 pretty low and I have vb3s with 245s in front and 5mm spacers, I rubbed a hope through my fender liner when I make hard lefts. No spacers in the rear 275s, no rubbing.
Carbon Black Metallic
SMG II
Verttttt
VCSL Front Bumper
VCSL 1 Piece Splitter
VIS GTR Hood
6K Angel Eyes
VMR VB3 19's
KW V2 coilovers
sakumaxp is offline   Reply With Quote
Old 04-26-2013, 12:17 AM   #7
Westrace
My Ride: 06 G35, 04 M3 Coupe
Just curious what you meant by flaring fender? I am on 19in. OEM with 275 on the rear and with just 5mm spacers, the rear tires would rub if going over bumps.
Westrace is offline   Reply With Quote
Old 04-26-2013, 01:20 AM   #8
sakumaxp
i think he means by flaring fenders would be pulling/rolling?
SMG II
Verttttt
VCSL Front Bumper
VIS GTR Hood
6K Angel Eyes
VMR VB3 19's
KW V2 coilovers
Old 04-26-2013, 07:55 AM   #9
toecap
My Ride: 00 323i 2.8L
Running 18mm front and 12mm rear on stock tire size 225/255. Pretty sure you will be rubbing hard if you put anything over 5mm running a 275 with stock fender.
toecap is offline   Reply With Quote
Old 04-26-2013, 09:25 AM   #10
03BIMMERM3
Literally rolling out the fenders to prevent the tire from rubbin with spacers, not sure if you'll notice in the pic, id do it with 275s
ID:	502527   Click image for larger version
Old 04-26-2013, 09:51 AM   #11
ECSTuning
ECSTuning's Avatar
My Ride: BMW
You're going to get a million different suggestions for spacers. Everyone's ride height, tire size, taste, etc is a little bit different. Due to this I always suggest measuring for spacers. Below is a video showing our suggested method for doing this. Once you measure you can easily select your spacers and new extended wheel bolts from my selection found HERE.
Old 04-26-2013, 02:20 PM   #12
M3 boyzky
My Ride: 2006 M3
As always, thanks very much for the suggestions!
