Random Voltage Drop...Pulling My Hair Out - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-24-2013, 03:24 PM   #21
jfoj
My Ride: 330CiC, M5, X5, E93
Originally Posted by jbatman View Post
Will definitely check that first. I have to remove the plastic shield to see that don't I?
That`s exactly why I told you to use the jumper cable test. I did not want to go into details as to what the purpose of putting the jumper cable between the engine and body was about until the test showed some sort of improvement.
Not sure you understood what/why I told you to perform the test??
Also you need to check very carefully that your serpentine belt is routed correctly and the tensioner is working properly. Not sure you can misroute the belt easily, but usually on an alternator you need about 1/2 a pulley wrap of the serpentine so you will not get any belt slippage. Believe me it happens. Maybe a picture of your belt around the alternator will give some clue if this could be an issue??
Old 07-24-2013, 03:45 PM   #22
jbatman
My Ride: 325i
I couldn't get a clear shot of the belt/alt..I'll have to wait until after work to get home and get the air filter box off to take a better pic. The trouble with the grounding test you suggested is that the voltage drop is random and I've never encountered it off a cold start. I see it sometimes when I'm coming back from lunch which would be the only time I would be in the position to do any sort of testing while the problem is happening and with the car immobile (without pulling over on the highway). Running that test over lunch in the parking lot in 100+ heat in business casual attire sounds miserable. I'll have a better shot at it over the wkend when I have more time.
jbatman is offline   Reply With Quote
Old 07-24-2013, 04:30 PM   #23
beasted86
My Ride: '02 BMW 325i
Originally Posted by Stinger9 View Post
Do you know the theory here? Hand held cannot load test obviously. Curious how it could give accurate results.
Yes, the handheld Midtronics unit is a load tester.
Like I said it is a reliable tester, and is the standard in all dealerships. All warranty claims require a Midtronics test with the failure code.
beasted86 is offline   Reply With Quote
alternator, battery, e46, voltage
