Old 05-08-2013, 02:20 PM   #21
SK330ci
My Ride: 02 330ci w/ 3 Pedals
Originally Posted by dreamdrivedrift View Post
GRM just released their tire testing article between the ZII and the Rival, with the Toyo R1R as a benchmark. Summary of it is that the Rival is a BOSS! Great tire at all psi, handles heat well, and they are tolerant of large slip angles. The ZII seems to be a more finicky tire that is more setup and heat dependent.
Now I kind of wish I got the Rivals, but nonetheless I can't wait to run my ZIIs in June
I just went to the GRM site, looks like you need a $20 dollar subscription to see things.
Can you copy and paste this tire test on here, I'd really like to read it.
Thanks.
Mods: Header, CAI, Shark, Koni Sport Struts, Rob43 9 Way Shocks, Big Sway Bar, Special Lowering Springs, 3.38 Diff, PFC Z-Pads, 75 Shot Of N20
E46 M3's are just tasty snacks i eat for lunch.
SK330ci is offline   Reply With Quote
Old 05-09-2013, 10:21 AM   #22
Kubica
My Ride: 2003 325xi
Originally Posted by SK330ci View Post
I've given this a lot of thought. I think after researching this, your answer is your 235/40-17. From a weight, gearing & Neg. camber stand point it's a winner over your other size choices. Brand consideration, well that could still go way few different ways; my choice is still the Hankook RS-3.
Thanks for your feedback!
Old 05-09-2013, 10:33 AM   #23
Kubica
My Ride: 2003 325xi
Go for the 17s with the 235s. Why do you have to reduce camber if you run a wider tire? Should be the other way around...run more camber with a wide tire
Each 'mod' done to the car increases your base points in the club I run with. If I add more camber or tire width, it would push me to a faster class unless I drop points somewhere else.
The reviews seem to support this. I find it difficult to control a slide with the Z1s at different temperatures or pressures sometimes. Back to back runs with the Z1s almost never feel the same.
Old 05-09-2013, 04:01 PM   #24
dreamdrivedrift
My Ride: 99 M3 & 95 325i
Send a message via AIM to dreamdrivedrift
Thanks.
Sure, I will do that now
edit: http://www.sendspace.com/file/v22cwv
Sorry about the quality, the way the reader works I couldn't get the typical 1 page/screen
Chris
dreamdrivedrift is offline   Reply With Quote
Old 05-09-2013, 07:13 PM   #25
SK330ci
Thanks, it's plenty good enough.
Old 05-11-2013, 09:46 PM   #26
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
I've heard the ZIIs aren't much different than the Z1s. I'm still quite sure that the RS3s > all for warm, dry grip. I think they increased the UTOQ to 200 so you can run them in Chump car now as well. Not sure if that has any affect on your auto-xing.
The downer with the RS3s is they are noisy, not so good wet grip, terrible in cold weather.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 09-18-2013, 10:17 AM   #27
Kubica
My Ride: 2003 325xi
How about cold weather grip? Which of the tires mentioned above will grip best around 50 degrees F?
I have two more autox at the end of October when it starts to get pretty chilly in NE.
I have a set of 235/40/17 AD08's that I can use....bad choice for a colder race?
