Australia
Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Old 04-26-2013, 05:42 AM   #1
aar0n_91
My Ride: 04 BMW325CI///MSport
HID help
so i ordered a set of p46's with orion V2 angel eyes, FXR projectors (bi-xenon), 55W D2S 5000k HID kit (low beam) from umnitza (as well as a H7 35W 5000k HID kit for inner reflector high beam and a 9006 35W 5000k HID kit fog light). i selected this option called pre-install so everything should have been plug and play (apart from the halos)
the package came in a timely manner. wrong globes were sent but that is in the process of being recitifed. everything has been good so far.
i installed the p46's today. did an initial test with the car off and everything worked fine. when i switch the car on the low beam would cut out after say 10s but high beam (reflector) and indicator still work
the HID's also flash as seen in the video. the lights deffinitley work.i think my car needs to be coded to accept the xenons and for the bixenon shutter to work.
im just confised as before these headlights i had 35W HID's in the low and high beam OEM housing (from jason) and they worked find (but an autoelectrician installed those so maybe he coded the car?)
any help would be appreciated
heres the link to the youtube clip. please watch it and advise
PS id like to say i will order with umnitza again. it has been a pleasant experience so far. theyve had great communication and have stuck to their word.
ID:	502521   Click image for larger version
BMW 325 CI ///M-SPORT INDIVIDUAL
aar0n_91 is offline   Reply With Quote
Old 04-26-2013, 06:21 AM   #2
aar0n_91
old HID in low beam were H7, new HID's in low beam are D2S if that matters
i also get bulb out warning on both sides shown on dash.........any sydney electrical specialists please help =D
or if you know an auto electrician who is good and will solve this share their info
Old 04-26-2013, 08:12 AM   #3
Jall
My Ride: 328Ci
Needs coding.
Bixenon shutter you will need to wire in (splice into the high beam wire).
Some ballasts work, some respond to the checks in the manner that yours do.
Jall is offline   Reply With Quote
Old 04-26-2013, 04:46 PM   #4
aar0n_91
Who do I get to code it?
Who would splice by bixenon shutter ino the hibeam
Who would wire up the angel eyes
Any Sydney fanatic able to help. Ill pay by the hour. Pm me please!
Old 04-26-2013, 06:04 PM   #5
umnitza
8774866489
umnitza's Avatar
My Ride: E39M5, Sequoia
Aaron, the lights look good. Please email us if you need any further support, we'll be happy to help.
To answer some of your questions, the bixenon shutter should already be spliced into the high beams for you.
The tech that installed them, make sure he keeps the headlights in Halogen mode if possible - one other thing to try is if he had the xenons in the car prior to this, see if those ballasts work (they should connect up as well) if they do, we'll have to figure out why and work with you on that.
For the angel eyes - it's very very easy - www.fastm.com - just follow the step by step guide (but in RHD format).
Old 04-29-2013, 06:40 AM   #6
aar0n_91
any info on an indi who can recode my lights for me? and wire up my angel eyes......... willing to drive all over sydney for someone good
Old 04-29-2013, 03:38 PM   #7
Jall
My Ride: 328Ci
Re: HID help
Drive to Melbourne and I'll fix you up.
Sent from my GT-I9300 using BimmerApp mobile app
Old 04-29-2013, 09:34 PM   #8
aar0n_91
I will genuinely fly you up here. Pm me me if your interested
Old 04-29-2013, 09:38 PM   #9
fgin
My Ride: e46 facelift
Drive to Melbourne and I too can code your lights out
fgin is offline   Reply With Quote
Old 04-29-2013, 10:06 PM   #10
Mitch E46
My Ride: M3 Convertible
Why did umnitza sell you a product that requires coding? There are plenty of ballasts out there that don't require this. Good luck nonetheless.
Mitch E46 is offline   Reply With Quote
Old 04-29-2013, 10:54 PM   #11
aar0n_91
Apparently it's not the ballasts. But I don't know anything about that stuff so.....
Old 04-29-2013, 11:28 PM   #12
Jall
My Ride: 328Ci
Re: HID help
It's the ballasts.... Or the coding, depending on which way you want to look at it. Some ballasts have error cancelling features, others don't. Unless umnitza has other information?
I prefer to have the correct coding than a bandaid fix with the ballasts.
Old 04-29-2013, 11:32 PM   #13
E46 Coupe
E46 Coupe's Avatar
My Ride: Rules1 & 2: S T F U!
Because Umnitza
E46 Coupe is offline   Reply With Quote
Old 04-30-2013, 03:01 AM   #14
aar0n_91
Jall, please provide detailed info on what coding needs to be done and what equipment is required to do it so I can ask the auto electricians specifically what they need to do.
Old 04-30-2013, 03:02 AM   #15
aar0n_91
Ps I'm not joking about flying you up as a last resort
Old 04-30-2013, 03:28 AM   #16
Jall
My Ride: 328Ci
Re: HID help
I can send you my gear up if you have a windows laptop and want to do it yourself and I'll walk you through it? Or you can buy your own if you can wait. Pm me.
Also, Steve.k (?) had the same adaptor I do so would have the ability to code it as well. Weren't you two mates?
Old 05-08-2013, 08:53 AM   #17
aar0n_91
anyone know what fuse number the low beam is and if its the same fuse for low and high beams and indicators..............from research all i find is that #9 and #32 control the lights, but thats as deep as the information i can find goes
also when checking fuses, what am i doing. i have no idea!! all i know is how to access them in the glove box......
Old 05-08-2013, 09:38 AM   #18
Jall
My Ride: 328Ci
PM'd with some more thoughts/suggestions/general musings after our chat today.
Old 05-10-2013, 07:29 PM   #19
aar0n_91
turns out it was the 55W ballast causing my problem. put a set of 35W ballasts from ED I had in and the lights are fine.
