///M3 Forum
Old 04-26-2013, 01:17 PM   #1
xsxpxhx
My Ride: 2002 M3
Summer is coming and my AC Unit is Acting up
Anyone know what the problem would be? When I turn on my AC the Temp Indicator goes up 3/4's of the way. When I had noticed this, I turned on the heater and it obviously went back 2/4's of the way. Anyone have insight on what it could be? Going to be soing on a long trip and going to get this checked out. Thanks. Happy Motoring!
xsxpxhx is offline   Reply With Quote
Old 04-26-2013, 02:58 PM   #2
illestminimike
My Ride: Project Drama
Sounds like a fan clutch. Inspect it and make sure it spins correctly and is clean.
If it's ok then replace your thermostat and flush/bleed your coolant.
Old 04-26-2013, 05:25 PM   #3
xsxpxhx
My Ride: 2002 M3
thank you sir!
Old 04-26-2013, 07:13 PM   #4
illestminimike
No problem bro!
Old 04-26-2013, 07:39 PM   #5
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
It going to be your aux fan. If your car is fine when running without the AC, but heats up with AC on, it is going to be your aux fan. Check BMAParts.com for one. You have to buy the whole fan, you can't buy the controller separately.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is online now   Reply With Quote
Old 04-26-2013, 07:59 PM   #6
illestminimike
Not exactly. It COULD be this but most of the time it's the fan clutch. At least on these cars.
Old 04-26-2013, 08:16 PM   #7
BMWCaptain
No, it has to do with his air conditioning and will be his Aux Fan. If it was the fan clutch, it would also overheat without ac.
BMWCaptainE46.com
Old 04-26-2013, 08:18 PM   #8
illestminimike
Not necessarily. I had the same problem as OP and it was my fan clutch. My aux was perfectly ok. Unless his isn't turning on. He should still inspect it.
Old 04-26-2013, 08:44 PM   #9
BMWCaptain
Yes, not necessarily, I had one where I would turn on the AC and then it would get hot. It was the AuX Fan Controller.
BMWCaptainE46.com
Old 04-27-2013, 11:31 AM   #10
xsxpxhx
My Ride: 2002 M3
Thank you bmw captain and illestminimark. I will inspect it and look for parts
Old 05-24-2013, 04:31 PM   #11
xsxpxhx
My Ride: 2002 M3
Ok, so I took it in and they checked it out. They did not see anything bad with the AC Unit. They drove my car with the AC full blast for 40 mins and nothing! I told them that this only happens when the weather is super hot. So it looks like we will have to wait til summer. Any one else know what the the problem woudl be?
SYMPTOMS:
When AC is on during extreme hot weather, my car indicates that it will overheat. The line is about 3/4 over. Although in moderate temps it acts normal....and ideas??? Thanks all!
Old 05-29-2013, 04:22 PM   #12
Faucette1954
My Ride: 2005 BMW 325ci
is there a test for the puller fan clutch to see if it needs to be replaced?
Faucette1954 is offline   Reply With Quote
Old 05-30-2013, 03:18 PM   #13
xsxpxhx
My Ride: 2002 M3
Ill ask about that
Old 05-31-2013, 01:57 AM   #14
xeux
My Ride: E46 M3 // E90 335i
Had the same problem on both of my M3s here in Phoenix during summer time.
Was the Fan Clutch BOTH times.
xeux is offline   Reply With Quote
Old 05-31-2013, 03:07 PM   #15
xsxpxhx
My Ride: 2002 M3
thank you xeux, i will look into that and possibly repair it. thanks alot!
Old 08-28-2013, 11:57 AM   #16
xsxpxhx
My Ride: 2002 M3
I just replaced the fan clutch and I still have the problem!!! I dont know what else to do.
