Swapped the internals from bi zenons into halogen housings - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-27-2013, 08:03 AM   #1
the xecutionr
My Ride: Imola M3 Vert
I picked up a set of oem bi zenons but the housings were a little beat up and the top clips were broken so I had the idea to just swap out the internals with my halogens. I asked for some opinions if the inside of the housings were the same and got no replies so i just went ahead and rolled the dice and tried anyway. The housings are the same size but there are some differences. #1 the insides are different, no holes to feed the harness..the spot for the auto leveling plug would need to be cut out and theres no recess on the projector side for the ignitor to sit in. #2 the headlight harness only has plugs for the low and high beam... no auto leveling plug..maybe something could be spliced but im just stating whats there.... and #3 what was the biggest pain in the ass, there is a such things as a left and right harness but being i had 2 right hand harnesses I had to make it work. I havent seen a left side harness but by the troubles i went through im guessing its sized differently so the back end of it doesnt hit against the airbox because that effectively keeps the headlight from sliding into place by alot. So after some trial and error I finally got the headlights in and of course they werent level but you can adjust that after the fact with the knobs on the back... I did get the headlight out indicator on the dash but its was before i changed the lcm and either way it would only be for about 5 sec after i turned the car on... only things is im waiting til later when its brighter to see if the auto on works because right now it turns the lights on but i dont know if its just doing it by default and just treating it as an on switch. Here are some picks before and after
ID:	502616   Click image for larger version
ID:	502617   Click image for larger version
ID:	502618   Click image for larger version
ID:	502620   Click image for larger version
ID:	502621   Click image for larger version
ID:	502622   Click image for larger version
THE ONLY THING I FEAR IS FAILURE, AND FAILURE IS NEVER AN OPTION. GO HARD OR GO HOME.
the xecutionr is offline   Reply With Quote
Old 04-27-2013, 09:13 AM   #2
Snik
Snik's Avatar
My Ride: IR M3 Vert.
Nice job.
I wouldn't replace the lcm. It also stores mileage. And I think if it doesn't match the other 2 locations in the car you may get a mileage tamper dot.
Would be cheaper to just code the current lcm or get an error eliminator which is what in using.
Glad to hear it worked tho. Looks good.
Do you ride a sportbike?
Old 04-27-2013, 09:16 AM   #3
tnhl1989
My Ride: 02 330xi(RIP),03 ZHP
Just get it coded
tnhl1989 is offline   Reply With Quote
Old 04-27-2013, 09:32 AM   #4
the xecutionr
Re: Swapped the internals from bi zenons into halogen housings
Originally Posted by Snik View Post
Nice job.
When i replaced it i didnt get a tamper dot... but i also havent moved the car
Old 04-27-2013, 09:34 AM   #5
the xecutionr
Its not so much the error i care about since it only lasts a couple seconds.. i want the auto on function
Old 04-27-2013, 09:52 AM   #6
Snik
Snik's Avatar
Just saying tho. I personally wouldn't touch the lcm. If the auto function doesn't work it def might need coding. Then u just code it to xenons at the same time. But I can't imagine why it wouldn't work.
Old 04-27-2013, 09:58 AM   #7
the xecutionr
No what im saying is my lcm didnt have the auto option since i had halogen headlights.. thats why i wanted to change the lcm
Old 04-27-2013, 08:48 PM   #8
the xecutionr
Ok so after starting the car after it sat a few hours with the new lcm i did get a tamper dot so i just switched back to the original
Old 04-27-2013, 11:07 PM   #9
My Ride: Lexus
Nice swap. glad you didn't just pop in $20 HID like DDM or some other BS like a lot of people do. +20 MP.
Old 04-28-2013, 08:34 AM   #10
the xecutionr
Actually the car came like that with the hids already installed in the halogens but i wanted an updated look
Old 04-28-2013, 08:38 AM   #11
TerraPhantm
My Ride: M3 & ZHP
Xenon / halogen has no bearing on auto function. If your car was an 02+ model and had a rain sensor, it had auto headlights. Otherwise it didn't.
You definitely have the tamper dot. You can easily fix that... But it'd make more sense to just use your original LCM and recode it for HIDs
Oh and it's "xenon" not "zenon"
Old 04-28-2013, 08:51 AM   #12
haurelio
My Ride: 2001 bmw 325i
Good job, it would have probably easier and better if you had retrofit them.
Anyway, let me know if you want the lights coded.
Contact me if you need to unlock your phone.
Also can code your car
Old 05-08-2013, 03:45 PM   #13
the xecutionr
Yea i changed back to original lcm and no more issues... i have rain sensors but my car is 01.... and i absolutely know its xenon i have no idea why i had the biggest brain fart making this topic.
Old 05-08-2013, 03:46 PM   #14
the xecutionr
Yea it probably would have now that i look back but oh well its done now.. no need for coding i had the error eliminators that came with the hids that came with the car... at least they did something right
Old 05-17-2013, 07:17 PM   #15
vladbimmer
My Ride: 2003 330i
Don't mean to thread jack, but do xenon lights work without car started? Or does it need to be started for them to work?
vladbimmer is offline   Reply With Quote
Old 05-17-2013, 07:29 PM   #16
Snik
Snik's Avatar
car has to be ON, not running.
