E46 Xi Forum
Old 04-27-2013, 08:46 AM   #1
kwain
My Ride: 2004 330Xi
Exclamation New to BMW, need help
Hi everyone. I recently got a screaming deal on a 2004 330Xi. The vehicle was owned since new by an older gentleman, and he obviously cared for the vehicle meticulously. He had recently replaced rear springs, (LR was broken, so he replaced both), front shafts (one cv boot was split, replace both complete shafts), pads, rotors and calipres.....
What I have is a rotational noise, at coast or under very light acceleration. It is coming from the front, for sure and the noise increases as speed increases. It stops immediately on light brake application, but there is no change in the sound with steering input, except at highway speeds. It will disappear, or increase on left or right shift, as if it was a wheel bearing issue. I am a sales manager at an import dealership (Not BMW!), and a couple of our more experienced techs have driven the car, and suggest simple fixes like a brake calipre bushing to a wheel bearing, to a cv joint.
Any suggestions??? I don't want to start replacing parts by guessing, and if needed, I will search for a well regarded BMW shop for diag if needed, but your expertise and experience may have already heard of a similar issue?!?
Thanks so much.
kwain is offline   Reply With Quote
Old 04-27-2013, 09:10 AM   #2
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Check you front bearing and axles. Those bearings can get to be expensive.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
bearing, cv joint, rotational noise
