Old 04-27-2013, 12:24 PM   #1
AndyN
My Ride: ESS TS2 325ci
ESS TS2 leaking from pulley
Hey guys, after the m54b25 engine blew I am putting the supercharger on an m54b30. Its all mounted and ready to go with the new pulley size and tune etc.
However I am noticing some oil leaking from the bolts on the S/c pulley. Does it just need to be torqued more or what could cause this?
AndyN is offline   Reply With Quote
Old 04-27-2013, 01:20 PM   #2
paraklas
My Ride: ESS TS2 320ci
Are you sure it's from the bolts? There's a hole in the middle of the pulley to prevent oil over filling. Last time I changed the s/c oil, I poured more than I should and it came out from that hole, sprayed the hood insulation a bit
Old 04-27-2013, 01:25 PM   #3
AndyN
Your right its coming from the hole, will I just leave it as it is and let the overflow spill out?
Sent from my GT-S5830i using Bimmer App
Old 04-27-2013, 01:32 PM   #4
paraklas
If you tilted the s/c then you might have actually lost oil, if that's the case it is better to drain and refill with the correct quantity
Old 05-11-2013, 11:50 PM   #5
AndyN
Thanks for that paraklas, engine is nearly ready now but as all the parts are back on its very hard to drain the supercharger oil without taking off parts again, should I just to up with maybe 20mm and let it overflow? No?
Old 05-12-2013, 02:23 AM   #6
TrippinBimmer
My Ride: Just Fast!
just let it overflow and spill out. it will make a mess but it will get to the correct level.
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
