E46 Convertible
Old 04-27-2013, 04:17 PM   #1
Snik
Snik's Avatar
My Ride: IR M3 Vert.
Verts and radar detectors
Ok guys. Where do u guys mount your radar detectors. Particularly, those of u with hidden setups.
Those that just suction cup it on, or clip it to the front by the lights. Not interested.
I'm curious as I want a V1 and I'm wondering after the stealth display is put in, where does the main unit go, is there a way to mount it where it can't be seen or stolen when the top is down.
Thanks.
Do you ride a sportbike?
Old 04-27-2013, 04:24 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
You won't be able to since both antennas need a clear view of the road.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 04-27-2013, 04:26 PM   #3
Snik
Snik's Avatar
Ok. So the main unit does the "looking" right?
Hmmm. Need to figure out something?
Old 04-27-2013, 04:32 PM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
Yes, the antenna needs a line of sight of the road to work properly. That's with any detector so it will still be out in the open. I would just run a hardwire up from the center console through the a pillar to where the drivers sunvisor is. Then with the cable there you can mount the detector up high and take it down when not being used.
Btw, the V1 is the best. Period.
Old 04-27-2013, 04:42 PM   #5
Snik
Snik's Avatar
Hmmm. Might have to go that route.
Old 04-27-2013, 05:52 PM   #6
linom3
My Ride: M3
Here is mine.
ID:	502707   Click image for larger version
linom3 is offline   Reply With Quote
Old 04-27-2013, 05:53 PM   #7
Solidjake
Zero. Leaks.
Solidjake's Avatar
^ You have a laser jammer?
Old 04-27-2013, 06:59 PM   #8
linom3
My Ride: M3
^ no, valentine 1
Old 04-27-2013, 07:03 PM   #9
Solidjake
Zero. Leaks.
Solidjake's Avatar
Yes, I know you have that but I'm referring to the switch.
I'm the radar master on this forum, don't forget!
Old 04-27-2013, 08:06 PM   #10
linom3
My Ride: M3
lol, the switch is not connected.
Old 04-27-2013, 08:23 PM   #11
Snik
Snik's Avatar
I like that setup. Where is your main unit located.
Old 04-27-2013, 08:53 PM   #12
wildirish317
My Ride: 2004 325Ci vert
How the hell can you speed in NYC? Are you a taxi driver by profession?
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 04-28-2013, 12:56 AM   #13
johnrando
My Ride: '06 330 CIC ZHP
I have mine hardwired, but I use the StealthOne, which shows the alerts on my Nav screen. So, I put the V1 high up on the windshield but to the right of the rear view mirror because I don't have to see it. BTW, V1 now sells a module that basically does the same thing.
John '06 330 Cic ZHP
Southern California
ZHP, Cold Weather Pkg., Leather, Jet Black/Black/Black Cube, NAV
AA Tune, Sprint Booster, BMW Perf. Intake, Magnaflow Exhaust, Dinan STEP S/W & TB, TMS Pulleys, H&R Touring Cup Kit
BMW Perf. Strut Brace, Orion V2 Angel Eyes, No-holes License Plate, SMG Paddle Shift Mod, Besian VANOS, Gold DISA, Fan delete
Old 04-28-2013, 01:03 AM   #14
Snik
Snik's Avatar
does the same thing as what?
Old 04-28-2013, 03:04 AM   #15
Retrax
My Ride: 2004 325CI vert
How about this? You probably wouldn't want to leave your detector on it with the top down though
www.blendmount.com
Retrax is offline   Reply With Quote
Old 04-28-2013, 07:16 AM   #16
linom3
My Ride: M3
www.blendmount.com
That's what I got, been using it for years on all my cars.
Old 04-28-2013, 07:16 AM   #17
linom3
My Ride: M3
Ill take a pic today.
Old 04-28-2013, 08:53 AM   #18
Snik
Snik's Avatar
www.blendmount.com
Yeeeeah. I like those setups.
Old 04-28-2013, 09:45 AM   #19
Solidjake
Zero. Leaks.
Solidjake's Avatar
Trust me, you can
I do a ton of highway driving too all over the place so in addition to my v1 I have laser jammers, a cb radio and police scanner
Old 04-28-2013, 10:31 AM   #20
Snik
Snik's Avatar
Yeah, especially if you know the roads, you knwo where the craters are... but you can def open up a car in NYC
