Old 04-27-2013, 09:11 PM   #1
jsmith0079646
My Ride: bmw 323i
blowing cold air when heater is on full blast
Hey everyone,
Can someone tell me why my heater is blowing cold air instead of hot air?
Well first i have a bmw 323i yr 2000 that i bought cash. Well to start it ws running hot but before i let it get to the read zone i shut it down i checked for leaks, but come to find out i needed to replace the thermostat housing and relaced the water pump as well but it contnues to run hot, when i turn he engne, i le it sit for about 30-45 mins at normal temp then about after that time elasps then it starts to go into the red zone, i sthut it down and let it cool. But here is the crazy part after i turn the car off the rad fluid is still cold and as i stated the heater never gets hot even when driving, the top hose gets hot, but the lower hose remains cold what could be causing bese strange events, lets not forget i have changed out the water pump, and thermostat housing, and its still doing the samething. Is it something im doing wrong or didnt do?
jsmith0079646 is offline   Reply With Quote
Old 04-27-2013, 09:56 PM   #2
haurelio
My Ride: 2001 bmw 325i
did you bleed the system?
http://forum.e46fanatics.com/showthread.php?t=914109
Contact me if you need to unlock your phone.
Also can code your car
Old 04-27-2013, 10:47 PM   #3
HacksawMark
HacksawMark's Avatar
My Ride: 2014 Subaru XV
Yes it sounds like you need to bleed the system properly.
HacksawMark is offline   Reply With Quote
Old 04-27-2013, 11:34 PM   #4
jsmith0079646
My Ride: bmw 323i
I was told that, but i didnt know what the hell they were talking about, if i did this will this also stop the overheating when at idle or in drive mode?
Old 04-27-2013, 11:53 PM   #5
HacksawMark
If done properly, it should. You have some air trapped in the system which are causing the problems you are having.
Old 04-28-2013, 12:04 AM   #6
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Check your heater control valve too.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 04-28-2013, 08:57 AM   #7
haurelio
It should.
Old 04-28-2013, 12:17 PM   #8
pawelgawel
My Ride: 330CI
you need to allow the engine to cool down completerly and allow the tstat to retract (open), then bleed the system properly... massage the lower and upper hoses if you can once in a while
pawelgawel is offline   Reply With Quote
Old 04-28-2013, 01:24 PM   #9
Stinger9
My Ride: '04 330Ci
OP, is your radiator fan working for sure?
You could have two separate problems.
Old 04-28-2013, 05:22 PM   #10
2003silver330i
My Ride: 03 BMW 330i
Fingers crossed that the overheating isn't some kind of head issue. My heater wouldn't blow heat either because the water/coolant was exited the tail-pipe due to a head issue but your issue sounds like water/coolant isn't getting into the engine.
2003silver330i is offline   Reply With Quote
Old 04-28-2013, 09:56 PM   #11
jsmith0079646
My Ride: bmw 323i
How much water was coming from tailpipe and did you exp constant overheating due to that problem? The reason i ask is becuz i saw some water, not a whole lot and it wasnt radiator coolant my father-in- law said that was condensation build up and that i should look at the oil and look for white smoke out the tail pipe. None of those checked out i didnt see no smoke nor did i see milky looking oil.
Old 04-28-2013, 10:31 PM   #12
2003silver330i
I didn't have any normal head issue symptoms from my car as well. However, I did have some condensation with no smoke from the tail pipe, no coolant in the oil, or no oil in the coolant. If you don't have a way of testing your head with either a leak down test or a combustion tester kit than try removing the coolant cap from the expansion tank. When the engine is cold, watch the coolant carefully, and if it rises slowly and starts pouring over once it reaches operating temperature then you have either a cracked head and/or a failed head gasket issue. Good luck.
Old 04-28-2013, 10:42 PM   #13
jsmith0079646
My Ride: bmw 323i
heater blowing cold
Thanx,
I bled the cooling system yesterday and what do u know the heater kicked in, now as far as it overheating i didnt let it run long enuf to see if it would or not cuz i got interrupted, but i will check tomorrow
Old 04-28-2013, 10:56 PM   #14
2003silver330i
Hopefully bleeding the system solved both of your issues.
Old 04-30-2013, 07:03 AM   #15
jsmith0079646
My Ride: bmw 323i
symbols
Hey ppl good morning,
I was wondering who could tell me what this symbol is. Well a symbol came up on my cluster reading yesterday in the shape of a sprocket with the letter i in the middle. This symbol came up in the shift area of the cluster the has the letters representing what gear u in. I'm thinking maybe it has something to do with the tranny, maybe check the fluid, or the fuid is low can someone tell me what that represents,
Thanx in advance.
Old 04-30-2013, 07:12 AM   #16
BMWCaptain
Thanx in advance.
Could be a problem with you DSC. Get your codes read from the car.
If not DSC, then could be transmission.
BMWCaptainE46.com
Old 04-30-2013, 09:16 AM   #17
jsmith0079646
My Ride: bmw 323i
symbols
What is a dsc?
Old 04-30-2013, 10:09 AM   #18
2003silver330i
What is a dsc?
Dynamic Stability Control:
This system monitors over- and under steer and adapts engine power and individual brakes to keep the car under control and headed in the intended direction.
Old 05-04-2013, 04:37 PM   #19
jsmith0079646
My Ride: bmw 323i
tranny
Can anyone tell me where do you check the transmission fluidon a 2000 323i?
Old 05-04-2013, 04:39 PM   #20
jsmith0079646
My Ride: bmw 323i
tranny
Its maki.g a whining noise
