Old 05-26-2013, 10:52 AM   #21
epistaxis2008
My Ride: 2002 330ci
Dont use autozone for the parts >>> http://forum.e46fanatics.com/showthr...065&highlight=
its been over a month and they stilll havent fixed their system u will get stuck with the wrong parts!!!
epistaxis2008 is offline   Reply With Quote
Old 05-26-2013, 12:17 PM   #22
jdstrickland
My Ride: '94 325iC & '00 323i
Idiots notwithstanding, it most certainly is a DIY job. You referred several times to using the T-25 to remove the fan, but what you really removed was the fan shroud. Yes, you gain some access, but my humble opinion is that the effort is not worth the gains. The Exhaust Cam Sensor should be able to be replaced without taking anything else off.
But at the end of the day, you replaced two parts that have been giving you fits, and of the two the Intake Cam Sensor was the real object of your obsession and is the more difficult of the two to replace -- mostly because the connector is in a crappy place. Anyhow, good job.
Old 05-26-2013, 03:19 PM   #23
epistaxis2008
My Ride: 2002 330ci
Re: ***Warning, this is not a DIY! *** both cam sensors replaced.
The fan comes out with the shroud taking just the fan blade itself out would be stupid. And my hands are huge so taking out the fan and shroud assembly as a unit is absolutely worth the effort, the added room is a necessity for large hands and big tools, if all u have is a larger socket set once you add an adapter and socket the length will give you problems if you don't remove the fan.
Old 05-26-2013, 03:47 PM   #24
jdstrickland
My bad. My car has an automatic, the fan and the shroud come out separately. The screw you point to is used to hold the shroud in. If the fan is connected to the shroud, that screw would be the one to remove.
But, on my car I can change the Exhaust Cam Sensor without taking anything else off.
Old 05-27-2013, 05:39 AM   #25
epistaxis2008
My Ride: 2002 330ci
Well then if your car is easier to work on than mine, you suck...lol!
Old 05-27-2013, 06:04 AM   #26
chudzikb
My Ride: 04 330ci
I loved the warnings. And glad to see you kept at it till it was fixed. No surrender, NO stealership!
chudzikb is offline   Reply With Quote
