Old 04-29-2013, 11:11 AM   #1
drawz
My Ride: BMW 3-series 325
Where should this hose go?
Hi guys! Got a E36 question for you..
I recently bought a 91 BMW E36 318i. My thoughts is to restore it and try to make a little profit on it. Got It 2500NOK! (427$)
The former owner of the car replaced the engine, and made a big mess in the engine bay! I have spent about 3 days to clean up and put things where they belong.
I have this last hose I can't figure out where it should go.. The hose was just hanging from under the car. Does anyone know where it should go? Here's some pictures for you guys. You can se the hose I've maked a red circle around..
drawz is offline   Reply With Quote
Old 04-29-2013, 06:45 PM   #2
2003silver330i
My Ride: 03 BMW 330i
Is there any vacuum to it when the car is running?
2003silver330i is offline   Reply With Quote
Old 04-29-2013, 09:19 PM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
You might check www.realoem.com??
Not dimensionally specific diagrams, but they may give you an idea of where the hose may go?
Old 04-29-2013, 09:27 PM   #4
lszlszx
My Ride: 1.8T, XC70
That hose is part of the emission system, it must be connected to the intake.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 04-30-2013, 02:40 AM   #5
drawz
I found It on realoem.. part #3 in this diagram; http://www.realoem.com/bmw/showparts...=13&fg=15&hl=6
Looks like It connects to the throttle houseing? hmm.
