Old 04-29-2013, 02:05 PM   #1
e46freak609
My Ride: 325 ci
confused!!!! car alarm went off??
ok so my alarm randomely went off on my car then when i go to turn it off it didnt work with my key , so i manually entered the car. car starts but windows dont work or lock and unlock.. any one else had this problem?
e46freak609 is offline   Reply With Quote
Old 04-29-2013, 02:06 PM   #2
XKxRome0ox
Black and Proud
My Ride: RIP e46/'16 328i
Your e46 is freaking out
[bimmerapp]
2016 BMW 328i 6MT/M Sport Package/Track Handling Package/BMW M Performance Exhaust/Injen CAI
XKxRome0ox is offline   Reply With Quote
Old 04-29-2013, 02:32 PM   #3
e46freak609
My Ride: 325 ci
Anyone
Old 04-29-2013, 03:03 PM   #4
e46freak609
My Ride: 325 ci
Bump i need help!!!
Old 04-29-2013, 03:32 PM   #5
mybmwisallst0ck
My Ride: BMW '02-330Ci, '99M3
I had an issue for a while where my alarm would go berserk all the time. Turns out it thought it was the hood being popped so I unplugged the hood sensor.
mybmwisallst0ck is offline   Reply With Quote
Old 04-29-2013, 03:35 PM   #6
e46freak609
My Ride: 325 ci
Yea i see but now its not my alarm anymore.. Now my door locks wont work and my windows wont function... I checked the central locking system fuses and nothing....
Old 04-29-2013, 04:44 PM   #7
e46freak609
My Ride: 325 ci
Bump need some professional advice!!!
Old 04-29-2013, 05:09 PM   #8
e46freak609
My Ride: 325 ci
Bump!!
Old 04-29-2013, 05:10 PM   #9
e46dinan
My Ride: E46 M3, E53 4.6is
Your siren has a small battery that need to be replace check that first.
e46dinan is offline   Reply With Quote
Old 04-29-2013, 09:58 PM   #10
e46freak609
My Ride: 325 ci
You think the siren has something to do with the windows and lock not working ?
Old 04-29-2013, 11:52 PM   #11
e46freak609
My Ride: 325 ci
Bump
Old 04-30-2013, 12:23 AM   #12
TallSkinnyMatt
My Ride: E92 M3 ZCP
unplug the battery for a while... then try it again!
TallSkinnyMatt is offline   Reply With Quote
Old 04-30-2013, 12:24 AM   #13
HacksawMark
HacksawMark's Avatar
My Ride: 2014 Subaru XV
What alarm do you have on the car? Door locks won't work and windows won't function? How about the rest of the car? Does it start okay? Drive okay?. Kinda sounds like a battery problem. Have you checked your battery voltage using the OBC?
HacksawMark is offline   Reply With Quote
Old 04-30-2013, 12:25 AM   #14
HacksawMark
That's a good thought! +1
Old 04-30-2013, 10:43 AM   #15
e46freak609
My Ride: 325 ci
Hacksawmark yea it starts up right away, i drove it around , i think ill drive to advance and get the codes read.
Old 04-30-2013, 03:01 PM   #16
e46freak609
My Ride: 325 ci
ok so i played around with the fuses and some of them had the wrong amperage so i put the proper ones on. connected back the battery and it seem like it was working .was able to put my window up and unlock my doors when it started doing the same thing again. my gas cap keeps locking along with my car . any ideas anyone?
Old 04-30-2013, 03:09 PM   #17
college46
My Ride: Alpine White
Get your codes read, stop bumping your thread every two seconds and report back. Search the forum. I found three topics with your issue in five seconds. You need a gt1 scanner to fully test your system however, it will tell you the faults in your system. Check your door sensors trunk hood sensors and check the OBC dash if its responding when you open them. Disconnect hood sensor and if all else fails, take it in.
Going to Bimmerfest West
01 325i ZPP 5 speed, 101,xxx
college46 is offline   Reply With Quote
Old 04-30-2013, 04:27 PM   #18
e46freak609
My Ride: 325 ci
i actually just realize it is the gm5 module. after searching around on the site i saw my car has all the characteristics pertaining the infamous gm5 problem. sorry i dont mean to bump its just its my only car and i need to go places lol...
Old 04-30-2013, 04:30 PM   #19
college46
search is your friend, it seems if you searched your problems yesterday you would have found your answer quicker. Good to see you diagnosed it!
Old 04-30-2013, 04:45 PM   #20
scottjoh
My Ride: '99 323i & '02 540i
Sounds like the general module up and died. I assume trunk release, interior lights and wipers are also not working.
scottjoh is offline   Reply With Quote
