Old 04-29-2013, 02:41 PM   #1
Chiefriley
My Ride: 2001 imola red 325ci
Wtf a solenoid valve....
First go at playing with the obd scanner, 2000 e46 convertible.
Didn't fully connect but I think I need to go through the round connection under the hood.
hOWEVER! These errors came up
and I'm already a little confused, I'm no mechanic so no digs please just a little help as to how or IF these need fixing...
Chiefriley is offline   Reply With Quote
Old 04-29-2013, 03:32 PM   #2
Chiefriley
Anyone....with da 'knowledge' out there. )
Old 04-29-2013, 03:44 PM   #3
WDE46
My Ride: '13 128i, '04 330Ci
Clear them. It says they are "shadow errors".
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 04-29-2013, 04:27 PM   #4
Chiefriley
Thanks wde46..,just out of curiosity, what are shadow arrows in 'layman' terms...
S
Old 04-29-2013, 05:09 PM   #5
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Shadow code is pretty much something that was stored a long time ago that pretty much is not in the system anymore, just something saved over time.
Old 04-29-2013, 05:14 PM   #6
///MPR77
My Ride: 02 ///M3 Tri-Ped
Re: Wtf a solenoid valve....
I think with your car you have to jump two pins under the hood, to get it fully connected.
Tock and I tried to get PA soft to connect to my OBD, it was giving some sort of connection error for the coding part.
Indirectly, I had mentioned this to Mango and he mentioned the jumpers, sorry I don't have more details.
Old 04-29-2013, 05:42 PM   #7
dknightd
My Ride: 2002 330 cic
is that the "PA soft" software. It seems to display "shadow" codes. Google it. Or search forum. As near as I can tell shadow codes are nothing to worry about and PA soft (at least the chinese bootlegs) can't clear shadow codes. You can clear them, then next time you scan the same ones will be back. As near as I can tell you can ignore these shadow codes. Of course, I could be wrong
dknightd is offline   Reply With Quote
Old 04-30-2013, 12:49 AM   #8
Chiefriley
Thanks everyone, really appreciate that...confused about the 'jump two pins' but ill try google it...
Thanks all
S
Old 04-30-2013, 01:16 AM   #9
MJLavelle
My Ride: 2001 BMW 330ci
Thanks all
S
Or, you could PM Mango...
Old 04-30-2013, 04:32 AM   #10
jfoj
My Ride: 330CiC, M5, X5, E93
The round 20 pin connector under the hood should have a cover and the cover should have jumpers in it. If the cover is installed on the round connector under the hood, the OBD connector in the car should work??
I do not have an older BMW so I cannot confirm this 100% but this seems to make sense.
PA Soft will display all sorts of errors, you need to ignore most of them as they will drive you crazy. A low battery can cause all sorts of codes to show up as well.
Old 04-30-2013, 04:42 AM   #11
Chiefriley
Thanks guys, starting to actually question the battery myself as when you buy a used car you never know what condition the batteries in, might drop in somewhere and ask if they can check it.
S
Old 04-30-2013, 05:09 AM   #12
jfoj
Especially convertibles as many times they are not primary cars and they sit a lot and the batteries get drained due to parasitic draw from the alarm and other modules.
