Old 04-29-2013, 02:52 PM   #1
Swater330i
My Ride: 2003 BMW 330i 5MT
Power Steering Issue
2002 BMW 330i
So today after the car has been sitting in a parking lot for about 6 hours I noticed that when I turn the wheel in either direction there is a noticeable popping sound coming from the engine bay while the car is running.
While I turn the wheel it makes very rapid little pops that sound a little like tiny farts or 2 pieces of rubber rubbing together.
Could there be something rubbing on a contact point or is this a sign of a troublesome Power Steering Pump that needs replacing?
Thank you for any advice received,
Sean T.
Originally Posted by phenom323ci View Post
I am going to install M3 fender grill on my 323ci.
Originally Posted by futureSubie View Post
IMO, the euro clear corners looks too aftermarket/ricey.
Originally Posted by Davconelectric View Post
This 323 would most likely handle and drive better than a stock e46 m3.
Swater330i is offline   Reply With Quote
Old 04-29-2013, 04:42 PM   #2
pcarney
My Ride: 2002 330ci
Fluid level?
pcarney is offline   Reply With Quote
Old 04-29-2013, 07:51 PM   #3
GEEZ_ITS_A_BMW
My Ride: 2000 323I
yeah check your ATF reservoir fluid level, your low and leaking somewhere
GEEZ_ITS_A_BMW is offline   Reply With Quote
Old 04-30-2013, 08:08 AM   #4
pcarney
My Ride: 2002 330ci
If it's not low...possible p/s pump issue.
Old 04-30-2013, 08:46 AM   #5
pic3
My Ride: 05 330i zhp
Check you tie rods also.
pic3 is offline   Reply With Quote
Old 04-30-2013, 12:40 PM   #6
pcarney
My Ride: 2002 330ci
Don't forget the reservoir has a built in screen/filter that can be clogged. Cheap DIY before you bite the bullet on the pump, and a good idea to replace when replacing the pump anyways. Of course flush...
I would think that locked up tie rod ends would make noise from the front end, rather than from the engine bay...
