Old 04-29-2013, 08:26 PM   #1
reyes186
My Ride: e46
Meyle wheel bearing ?
Have anybody used Meyle wheel bearing from ECS TUNNING ? How are they compare to other brands.? I'm in Need of front wheel bearing and I was looking at Meyle wheel bearing from ECS.
reyes186 is offline   Reply With Quote
Old 04-29-2013, 08:56 PM   #2
Sweetness
My Ride: '01 325i
Look no further than this...
http://www.autozone.com/autozone/par...6476_461303_0_
Branded as Timken, but most of the time comes as a F A G unit, which is OEM. Timkens are known for great quality nonetheless
2001 325i ZCW, ZPP
Titansilber Metallic, Black Interior
The 160,000 mile, clean daily driver
Sweetness is offline   Reply With Quote
Old 04-30-2013, 12:50 AM   #3
paraklas
My Ride: ESS TS2 320ci
I went with F A G assembly, no issues. I replaced the factory installed which were SKG
Old 04-30-2013, 12:54 AM   #4
My Ride: 2016 Lexus
I installed OEM rear wheel bearings from bmaparts.com
Best price anywhere on the planet @ $37 each. (at least at the time of purchase)
A job I never want to do again...
Old 04-30-2013, 01:13 AM   #5
reyes186
My Ride: e46
Thanks you guys ..
Old 04-30-2013, 02:21 AM   #6
MJLavelle
My Ride: 2001 BMW 330ci
That seems to be a hit or miss deal, with more misses reported lately. But, it would not hurt to go by the local store, and check the brand of bearings in the hub, if they have them in stock.
Old 04-30-2013, 04:15 AM   #7
Vandyinc
My Ride: 2000 323 Cic
I did the Autozone Timkens. Tore it all apart this past Saturday, opened the Timken box to find KOYO's inside. Since it was apart, I used them, not real happy with the slight of hand they did, but will give them a try. Worst case, I replace them again in a few months. Lesson learned.
Done:H&R Sport Springs Koni STR Shocks & Struts, Lower Control arms, FCABs, OFHG, CCV, Cooling Sytem refresh, Coolantsnitch. Yet to do:Transmission fluid & filter, VCG
Vandyinc is offline   Reply With Quote
Old 04-30-2013, 06:40 AM   #8
reyes186
My Ride: e46
Originally Posted by bigbaby View Post
what car are you driving?I don't think is a good thing...
325i
Old 04-30-2013, 10:45 AM   #9
TerraPhantm
My Ride: M3 & ZHP
Nothing wrong with Koyo. They made some of the e39 bearings and make them for pretty much all Japanese cars. Should be plenty reliable, maybe even more reliable than ***
Old 04-30-2013, 10:47 AM   #10
My Ride: 2016 Lexus
you naughty boy, you. your first censor.
yes but +1 Koyo=good. not everything has to be german, nor is it. The condensers are Nippondenso. Toyota/Honda's largest supplier.
Old 04-30-2013, 05:15 PM   #11
reyes186
My Ride: e46
Will I be needing an enlightenment after this job ? Just asking .
Old 04-30-2013, 05:18 PM   #12
TerraPhantm
My Ride: M3 & ZHP
No, most of us get by without finding our inner peace after doing wheel bearings.
If you meant alignment, that's not necessary either.
Old 04-30-2013, 05:26 PM   #13
reyes186
My Ride: e46
Thanks for the help guys ..
Old 05-01-2013, 08:39 AM   #14
Mr.Philadelphia
My Ride: 2002 330i
Indeed, Japan makes the best bearings (e.g., Koyo, NSK, NTN).
Mr.Philadelphia is offline   Reply With Quote
Old 05-01-2013, 10:15 AM   #15
CirrusSR22
My Ride: E36 318ti, E46 323it
The factory bearings on my 97 Legacy were Koyo. Just replaced one at 190,000 miles with a Japanese made SFK bearing that actually had Koyo engraved on it.
CirrusSR22 is offline   Reply With Quote
Old 05-01-2013, 10:30 AM   #16
My Ride: 2016 Lexus
I'm pretty sure it's about bearing standards and ratings and not necessarily country of origin although some good bearings could come out of that country you mention.
Old 05-03-2013, 07:42 AM   #17
Mr.Philadelphia
My Ride: 2002 330i
Sure, various load ratings as well as L10 and Ln ratings are published by the major bearing manufacturers. That said, most bearings never reach their L10 life for reasons other than bearing quality (e.g., lubricant contamination, corrosion, faulty installation).
Calibration and replacement of plant machinery is necessary to maintain optimal tolerances of finished products. Equipment at bearing factories takes a beating given the materials used to manufacture them. As such, the best bearings come from the newly opened plants operated by a reputable bearing company (e.g., NTN, SKF, ***) -- virtually all bearings from such a factory during the first month of operation are ABEC 9.
In my experience, the Japanese manufacturers have the most consistent quality control. I've also never heard a bad thing about SKF products. In this particular application, the design and quality of the rubber seals is perhaps more important than the bearing itself.
