Old 04-29-2013, 09:27 PM   #1
sandman512
My Ride: 2005 325I
Strange clunking noise coming from front end and strange grinding noise when stopping
History. 2005 E46
47,xxx miles
New Front Control Arm Bushings.
New front/rear brakes.
Problem: When going over lets say a speed bump, I hear a clunking type noise in the front end. To pull into the my garage, I have to back up first and I hear the noise hear and when going over the small garage lip. Another issue is that I'm also experiencing a grinding type noise when coming to a stop. It sounds like GRRRRRRRRRRRRR. Any input would be appreciated. Thanks!
sandman512 is offline   Reply With Quote
Old 04-29-2013, 10:16 PM   #2
///MPR77
My Ride: 02 ///M3 Tri-Ped
The clunking sound is possibly the Sway bar End links. They're relatively cheap.
You might start shopping around for a complete suspension overhaul, as you're nearing 50k miles.
The grinding noise, assuming its a rotational sound...could be a sticking caliper, possibly a wheel bearing, maybe just uneven worn out pads. <----(Edit) forgot that you have new pads...new rotors too?
GL
Old 04-29-2013, 10:23 PM   #3
sandman512
My Ride: 2005 325I
Thanks for the reply. I'm pretty sure the grinding noise sounds like it is coming from the front end.
Edit: yes,new pads and rotors.
Old 04-29-2013, 11:27 PM   #4
kimfogs
My Ride: 'Vert
Bad caliper pin! Mine did the same thing. $10 fix
~From a girl who knows cars!~
kimfogs is offline   Reply With Quote
Old 04-30-2013, 06:42 AM   #5
sandman512
My Ride: 2005 325I
Do I need to replace the just the pin?
Thanks!
Old 04-30-2013, 11:50 AM   #6
///MPR77
Re: Strange clunking noise coming from front end and strange grinding noise when stop
If indeed that is whats causing YOUR grinding problem, then you probably don't even need to replace it, just clean the pins up really well, and lube them...remember we're just guessing based on our own experiences.
Also check the dust/splash shield that covers the back of the brake rotor, sometimes they get bent, and make contact with the rotor as well, causing a scraping sound.
Old 04-30-2013, 11:51 AM   #7
My Ride: 2016 Lexus
I must spank you, Mike.
BMW TIS specifically says to keep pins DRY. No lube. That means no Gummi, either. D has been a bad influence on you.
Old 04-30-2013, 01:27 PM   #8
///MPR77
Damn...I have been lubing the pins forever Thanks for the heads up.
So just clean them really well with brake cleaner, and simply reinstall?
I am going to have to clean mine now
Old 04-30-2013, 01:28 PM   #9
My Ride: 2016 Lexus
Yes. the idea is that the grease attracts dirt and clumps it up together and jams things. Also some greases may deteriorate the bushings. So lose/lose. I know on most cars, you lube them.
Old 04-30-2013, 01:30 PM   #10
///MPR77
Originally Posted by mango View Post
i must spank you, mike.
Old 04-30-2013, 01:32 PM   #11
My Ride: 2016 Lexus
Old 04-30-2013, 01:32 PM   #12
///MPR77
And that's why I always have to scrub little chunks of crap off them every brake job.
Thanks dude, You are the man!
Old 04-30-2013, 01:35 PM   #13
My Ride: 2016 Lexus
Interesting. no problem good thing i memorized a lot of TIS info. i hope they bring it back online
Old 04-30-2013, 02:53 PM   #14
caryalon
My Ride: 2001 325i
Check that the caliper to carrier mounting bolts are tight. If they weren't tightened, that can cause the clunk...
caryalon is offline   Reply With Quote
Old 04-30-2013, 03:02 PM   #15
Schlag96
Slightly Modded ///Member
Schlag96's Avatar
My Ride: 1999 323i
yeah the clunk is definitely sway bar end links. I have the same thing. Confirmed by two different BMW mechanics lol
Schlag96 is offline   Reply With Quote
Old 04-30-2013, 04:11 PM   #16
sandman512
My Ride: 2005 325I
Where did you order the sway bar links from? Thanks!
Old 04-30-2013, 04:12 PM   #17
My Ride: 2016 Lexus
why do people continue to ask "where did you get such and such part from?" you can get any part anywhere. click on the vendor list
Old 04-30-2013, 04:14 PM   #18
college46
My Ride: Alpine White
Why do people not search the forum? is this the first time this clunk has been diagnosed as sway bar end links? Ignorance is bliss.
Going to Bimmerfest West
01 325i ZPP 5 speed, 101,xxx
college46 is offline   Reply With Quote
Old 04-30-2013, 05:09 PM   #19
sandman512
My Ride: 2005 325I
While I am well aware of the vendor/sponsor list, I ask the question for a few reasons.
1) The buyer might be able to point me in the right direction as far as a GOOD price.
2) The buyer might or might not be happy with the vendor/sponsor experience thus influencing my decision.
Thanks for the valuable input. I guess since you've been a member from Jan. 2013, all these people who don't search just annoys you? FWIW, the search function was done and their were multiple threads, but I figured I would throw it out there and see if anyone has any recent information that might be pertinent to my situation.
Old 04-30-2013, 05:11 PM   #20
My Ride: 2016 Lexus
You could rephrase your question then because "where can i buy xx part" sure sounds like "where can i buy xx part."
bmaparts, oembimmerparts, getbmwparts, esctuning are all good places to start.
GL!
