Old 04-29-2013, 09:38 PM   #1
Br3tt71
My Ride: 2000 BMW 323i
Cluster lights out
I had taken my car to a shop that specializes in BMWs for an EML issue. They ended up replacing my MAF sensor and it seems to have done the trick with fixing my limp mode problem ( knock on wood) but when I took it in he had run a complete diagnostic on the car and asked me if I had ever seen a check engine light on my cluster. I told him no and he said tht the reason was because the light was out. I ran a test on the cluster and it seems that there are a couple lights out including the DSC which hasn't worked since I bought the car. How do I fix these missing lights?
Br3tt71 is offline   Reply With Quote
Old 04-30-2013, 02:32 AM   #2
FastCHAZ
My Ride: 02 325ci
Best I could tell ya is to check your fuses.
Glove box & under the hood. I'm not sure though
But I'd start there.
FastCHAZ is offline   Reply With Quote
Old 04-30-2013, 11:47 PM   #3
Br3tt71
Bump
Old 05-01-2013, 12:59 AM   #4
cvx5832
My Ride: 325Ci, 325Cic, C300
Are you the 1st owner of this car? If not, it sounds suspicious that the CEL and DSC lights are the only ones out. It's a possibility that someone took the cluster apart and taped or disabled the LEDs to those warnings.
cvx5832 is online now   Reply With Quote
Old 05-01-2013, 01:46 AM   #5
Megalocnus
My Ride: 05 330i ZHP/MT
Hm, the few lights that are missing look like they were selected specifically (SES, DSC). Is the SRS (the airbag) light coming ON briefly by the way?
How may previous owners has your car got? Chances are one of them went in there with a screw driver and "fixed" them...
Megalocnus is offline   Reply With Quote
Old 05-01-2013, 06:13 AM   #6
NumbaOneNewb
My Ride: 2003 330CI Silver
If you look at my photo album, you can see that I swapped out all the leds in my cluster to a color of my choice. It's quite simple actually. In fact, it's easier to remove them than to solder them on. They could've also placed black tape over or behind the plastic coverings, blocking the light. I think that would've been the easier route, seeing as many aren't as brave when it comes to taking a soldering iron to electrical circuits. It's easy, but doesn't mean anybody can do it.
Although your picture quality isn't the best that I could make out the finer details, the lettering on the dsc triangle, check engine light, airbag technically are engraved on a black background leaving the lettering clear in color. Any led behind it would shine at its color spectrum beautifully. It looks like perhaps a sharpee was used to color in the plastic plating, and also taped up as well. The sharpee would've allowed light to bleed through
I take that back, it looks as if the section that was meant to be blocked was spray painted over. Most definitely. The coloring seems all too uniform on the front. Sharpee or something to hide it back there would be too obvious. They probably colored in the led with a sharpee too.
Have you tried holding the dsc button down while the car is running? If the light turns on, I think i have the answer.
Sent from my SPH-L710 using Bimmer App
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 05-01-2013, 09:23 AM   #7
Br3tt71
I have tried holding the dsc button down. Nothing happens. Also I am the third owner of the car so there is a possibility some one "fixed" it
Old 05-11-2013, 03:40 PM   #8
Br3tt71
So look what I found while taking my cluster apart. Apparently the owner before me decided to black out some lights.
ID:	505034   Click image for larger version
ID:	505035   Click image for larger version
ID:	505036   Click image for larger version
Old 05-11-2013, 03:42 PM   #9
Br3tt71
Anybod know how to fix this?
Old 05-11-2013, 04:38 PM   #10
scottjoh
My Ride: '99 323i & '02 540i
Alcohol and a Q-tip should remove sharpie ink without damaging the plastic or the lettering.
scottjoh is online now   Reply With Quote
