Stutter diagnostic - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-30-2013, 06:59 AM   #1
florida2002m3
My Ride: 330 ZHP
Stutter diagnostic
Figured I would throw this out and see what you guys think. 2003 ZHP, 120K.
Within the last year Ive had 2-3 stalls. After the stall, the car starts right back up. Runs 100%. Had codes read, it was a intake o2 issue. So i changed all the boots.
But this morning, 6th gear.... a little blip on the throttle..... stutter, stutter, 4th gear blip.... stutter, stutter...... EML light comes on, low bouncing idle as I coast into a parking lot.
A little cursing later, I start it up: no lights, smooth idle for about 3-5 seconds. Then low bouncy idle, but no lights.
Turn car off, curse some more then try again: same results.
Called the bossman, was about to call AAA for a tow. Figured I would give it one more try. This time I kept the throttle about 50% after I started it, ran smooth, reved up to 4K a few times. Let off the throttle, car idled fine. Drove to work, no issues. I plan to get the codes read this weekend.
My thoughts:
Possibly fuel pump and or filter, both were changed out to OEM about 10K ago.
Clogged injectors?
Highest probability: Vanos. Its making noise, I have the besian rattle and seal kit sitting in my garage. Ive just been timid todo it.
Will vanos issue throw codes?
What are the thoughts from the E46fanatics??
Last edited by florida2002m3; 04-30-2013 at 07:00 AM. Reason: forgot to add the year/model of car
florida2002m3 is offline   Reply With Quote
Old 04-30-2013, 08:48 AM   #2
scarede46er
My Ride: 2001 BMW 325i ZSP
Without reading the codes, we can only guess. And probably guess wrong.
Old 05-02-2013, 05:02 PM   #3
PainBreak
My Ride: 2004 325i
My thoughts:
Clogged injectors?
Probably wouldn't hurt to have a shop update your DME to the latest code revision. It solves some similar stuttering issues, although not exactly what you're describing. Check out the link in my sig.
Is your car a Stu Stu Stammering Stan at 2800 RPMS? FLASH THE DME! http://forum.e46fanatics.com/showthread.php?t=966614
Enco B046 Android 4.04 Root/FAQ/Help: http://forum.e46fanatics.com/showthread.php?t=967737
PainBreak is offline   Reply With Quote
Old 05-02-2013, 09:25 PM   #4
JetBlackCI
My Ride: 2001 330CI
Hows your DISA?
JetBlackCI is offline   Reply With Quote
