Old 04-30-2013, 02:37 PM   #1
e46_coupe
My Ride: 2001 330Ci
Squeaky Serpentine Belt Need Some Solutions
So my serpentine belt started with a really annoying squeak that gets louder as the motor revs. My first though was a bearing is bad, I replaced the water pump, rebuilt alternator, replaced the idler pulley, the tensioner pulley, and the I disassembled the power steering pump and everything looked good. I also installed a new belt. All the pulleys look good no chips out of them or anything, the tensioner does not seem to be bad because i push on it and it doesn't move very much. When i spray WD40 on the belt the squeak temporary goes away. It doesn't sound like the belts slipping either so I'm stumped. Has anyone ran into this problem? Any Ideas?
e46_coupe is offline   Reply With Quote
Old 04-30-2013, 02:40 PM   #2
WDE46
My Ride: '13 128i, '04 330Ci
So, you have replaced everything but the tensioner. Replace the tensioner. Just because you push on it and it doesn't "move very much" doesn't mean that it is applying the correct force to the belt. Don't put WD40 on your belt. It is supposed to be dry. That stuff may harm the rubber also. A wet belt will also get dirty and screw up your pulleys.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 04-30-2013, 02:42 PM   #3
e46_coupe
My Ride: 2001 330Ci
The squeak goes i run the car with no belt and the car is a 2001 330ci if it matters
Old 04-30-2013, 02:43 PM   #4
e46_coupe
My Ride: 2001 330Ci
Alright i will replace the tensioner, and get the wd40 off hopefully it works
Old 04-30-2013, 02:46 PM   #5
WDE46
Just make sure you get the right tensioner. There is a mechanical and a hydraulic tensioner available. You want to get what you have currently.
Old 05-03-2013, 11:50 PM   #6
e46_coupe
My Ride: 2001 330Ci
Update: So I replaced the hydraulic tensioner today and it still squeaks, when I spray belt dressing on the belt the squeak goes away which makes me think its something with the belt. Anybody have any ideas what else it could be
Old 05-04-2013, 12:03 AM   #7
MJLavelle
My Ride: 2001 BMW 330ci
Replace the belt. They are not expensive. What brand is it?
Old 05-04-2013, 11:45 AM   #8
e46_coupe
My Ride: 2001 330Ci
Brand new belt, I forget the brand name though.
Old 05-04-2013, 11:51 AM   #9
tommy d
My Ride: 2005 330i
So you had the noise before the replacement parts and still have the noise?
Current Vehicles in my stable:
2005 BMW 330i - 126K miles
2005 Mazda Tribute s - 117K miles
1998 Ford Taurus SE - 115K miles
1987 Ford Mustang LX 5.0 - 248K miles
tommy d is offline   Reply With Quote
Old 05-04-2013, 11:59 AM   #10
Stinger9
My Ride: '04 330Ci
Sounds like you got a contaminated pulley.
Clean each of them well, getting into all the grooves.
Old 05-04-2013, 12:36 PM   #11
WDE46
Sorry my thoughts didn't work. Maybe you just have a dirty bearing or something stuck in a pulley somewhere.
Old 05-04-2013, 12:48 PM   #12
Blueandwhite85
My Ride: E46
I'm dealing with an issue similar to this one. Sucks
Blueandwhite85 is offline   Reply With Quote
Old 05-04-2013, 12:51 PM   #13
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Take a picture of the belt for us. Also check for oproper routing of the belt.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 05-04-2013, 12:51 PM   #14
Stinger9
My Ride: '04 330Ci
Originally Posted by Blueandwhite85 View Post
Sucks
If you get all the pulleys clean with a new belt, gotta stop the squeak.
Here is the way your belt should snake around the pulleys.
Old 05-04-2013, 01:30 PM   #15
Roby G
My Ride: 2005 325 Ci
Definitely check for correct belt routing, is belt correct size ? length, width, cross section matter .... is the belt ribbed .... try another belt from a different source ... pulleys all bolted snug and lined up ?
Ive had incorrect belt sizes sold to me from known auto suppliers, with no install issues, then slipping, squeaking and thrown belts occuring later down the road ... belts were off by 1-2 cm or V / Sq. cross sections slightly different from manufactures
f sake ! quit sprayin WD-40 on the belt and pulleys !
Burnin Arizona Heat Wave !
Roby G is offline   Reply With Quote
Old 05-04-2013, 01:32 PM   #16
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
What brand is the belt? Maybe a cheap-o brand will squeak where the OE (Continental Contitech) is less likely to.
Old 05-04-2013, 02:01 PM   #17
e46_coupe
My Ride: 2001 330Ci
The belt is a Continental Contitech that i bought from a local BMW specialist. The belt seams tight, all the pulleys are alined and they all seem to be in good shape. I took all the pulleys off thoroughly cleaned them and the squeak went away from about 10 minutes then came back. The only thing i wonder about is my crank pulley, i recently rebuild the engine and used a crank pulley off of a 2003 330xi. Does anyone know if they are different?
Old 05-04-2013, 02:06 PM   #18
Stinger9
My Ride: '04 330Ci
I think you've stumped the band!
Hard to give any more insight from this distance.
Old 05-04-2013, 03:18 PM   #19
Blueandwhite85
My Ride: E46
Same here. All pulleys and tensioners are good, brand new contitech belt and it squeals. Gets louder with acceleration and is the least noisy when the engine is good and warm. Only different aspect is I'm running the ECS aluminum WP pulley. Haven't seen or heard any other people saying it's noisy though. OP, if you can find a Gatorback belt, use it! I'm searching for one now. Goodyear makes them.
Old 06-06-2013, 10:21 PM   #20
e46_coupe
My Ride: 2001 330Ci
Kinda Bringing it back from the dead but i have solved the problem. My coolent reservoir was leaking onto the belt causing it to sqeak. The leak was very small didnt notice it at the time but got worse. I replaced it and the belt and the sequeak has not came back. Kinda pissed i spent all the money on the pulleys but what ever now its new.
330, belt, e46, serpentine
