E46 Convertible
Old 05-01-2013, 02:57 PM   #1
E46conv325
My Ride: 02 325ci Convertible
Rip in the inside of the roof
Hello everyone - I recently purchased a 325ci and it came with a small tear in the rear passenger side in the inside about an inch wide. It is right about the rear window on passenger side at the seam where it meets the window. This is causing the inside liner in that area to sag a little. Was wondering if there was a fix to this or an economical but reputable place in the New Jersey area that can fix it? And how much approximately that would cost?
Thanks!!!
E46conv325 is offline   Reply With Quote
Old 05-01-2013, 03:05 PM   #2
taylor192
My Ride: 2003.5 M3
Check that your batwing is not broken, nor the string that supports them. Search this forum for "batwing" to see what I am talking about.
I would not operate the top until you've confirm the batwing and string are not broken, you might do further damage.
Old 01-01-2015, 02:45 AM   #3
carryonjutta
My Ride: BMW
Send a message via ICQ to carryonjutta
carryonjutta is offline   Reply With Quote
Old 01-13-2015, 01:31 PM   #4
phillz46
My Ride: 2002 330Ci Cabrio
I had a damaged bat-wing on my 2002 330Ci a couple of years ago. I caught it before the tear in the headliner got too big. I was able to get the OEM parts from Bavarian Auto but it took a about 2 weeks. The kit includes both sides but I only did the passenger side. I think the kit was around $75.00 but not sure. I'll probably get the other side fixed this year before it fails. I had mine repaired by WJ Auto Tops in Willow Grove, PA (NW of Philadelphia) for around $100.00 if I remember correctly. The stitch isn't pretty but the lining is still intact. Don't wait for the tear to get bigger.
phillz46 is offline   Reply With Quote
