Sponsored by BimmerWorld
Old 05-01-2013, 02:45 PM   #1
patdown
My Ride: 2005 BMW 330Ci
RTAB Replacement and cluster warning lights
I recently replaced my struts/shocks with Koni FSDs and also replaced my RTAB's with M3 style and poly type limiters. After I completed all of the maintenance, I was ready for a test drive and then on to an alignment.
As soon as I started the car, I had yellow DSC, ABS, and BRAKE lights illuminated on the instrument cluster. I checked the blue and black connectors that were disconnected during the RTAB replacement and they were secure. At that point, I thought I had broken a wire on one of the pulse generator sensors on one of the wheels. I got online to see how to test the pulse gen wiring harness. I ran across a thread that stated if you have these lights illuminated, just drive the car 5-8 mph and they will go out.
Sure enough, started driving the car and they went out an all was well. I hadn't seen anyone address this problem before on the RTAB DIYs. Doesn't mean someone hasn't addressed this issue, just that I had not read about it.
I don't know if this happens every time the blue and black connectors are disconnected and reconnected as in the RTAB replacement, but I sure wish that I had known about this from the beginning. I would have been expecting the lights and would have known to just drive the car.
Hope this helps someone.
Pat
2005 330Ci ZHP 6MT
AA Tune, domestically engineered CAI w/aFe Pro S, UUC TSE3,
Cooling Sys ovhl with Stewart WP, BMW M3 Front Strut Brace,
Koni FSD struts/shocks with original springs,
Cryo-Stop Rotors, Akebono Euro Ceramic pads, SS Brake/Clutch lines, CDV Delete,
Mason Engineering clutch pedal, Umnitza Predator Orion AE's, smoked corners and sides,
VMR V710 18" Staggered w/Hankook Ventus V12 235's/FR and 265's/RR
patdown is offline   Reply With Quote
Old 05-07-2013, 03:26 PM   #2
Drew@Swift Motorworks
Past Site Sponsor
My Ride: Scooty Puff Jr
Its not a problem that happens every time, but it does happen from time to time when doing suspension work. Thanks for giving everyone a heads up
Drew@Swift Motorworks is offline   Reply With Quote
Old 05-07-2013, 04:49 PM   #3
patdown
Since it doesn't happen every time, I guess that's why other diy's don't cover it. It sure caused me some concern until I found out what to do.
Pat
2005 330Ci ZHP 6MT
Old 05-07-2013, 07:16 PM   #4
Past Site Sponsor
It's always a scare to see those lights come on
Old 05-08-2013, 12:38 PM   #5
kfiggins
My Ride: e46 330ci ZHP
i've done suspension work on my car many times and have never had a dash light come on afterwards...
kfiggins is offline   Reply With Quote
Old 05-09-2013, 12:08 AM   #6
patdown
I guess I'm just lucky.
Pat
2005 330Ci ZHP 6MT
