Sponsored by BimmerWorld
Old 05-01-2013, 06:37 PM   #1
daveion2002
My Ride: 2001 330i
Spring or shock absorber problem?
So the right side of my rear wheel rubs like crazy when i go over dips, leave driveways, and hit larger bumps in the road. The Left is totally fine and is at the same height as my right. My question is: Do you guys think the spring or the shock is bad?
daveion2002 is offline   Reply With Quote
Old 05-01-2013, 06:49 PM   #2
HELLBOUND
My Ride: 2004 BMW 325 CI
First thing which would come to mind is the shock is blown and has no damping. If the spring where bad and or broken this would change ride height I would think.
Tc Kline s/a coilover suspension
Tc Kilne cast/camber plates
Hotchkis 30mm front swaybar
HELLBOUND is offline   Reply With Quote
Old 05-02-2013, 09:49 AM   #3
daveion2002
My Ride: 2001 330i
Alright sounds fair enough that's what the people I bought the shocks from so I was just getting second opinions before buying a new one
Old 05-02-2013, 10:18 AM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
+1 on checking the spring. The rear ones are known to crack.
Old 05-03-2013, 05:55 PM   #5
daveion2002
My Ride: 2001 330i
They are actually aftermarket coil springs and shock absorbers. They look okay no rust or cracking. You're right about the oem cracked the originals were totally snapped when i replaced them
Old 05-03-2013, 08:19 PM   #6
HELLBOUND
By this reply it seem like a brand new suspension is in place, so it could be something else. Kind of wondering if the battery location being just behind the rear right wheel well and with that extra weight there could be some effect.
Old 05-04-2013, 11:53 AM   #7
daveion2002
My Ride: 2001 330i
Yeah they are about 3 months old. I dont think its the battery though. I had my girl and her friend sit on top of each other on the good side and i could not get that one to rub. they weigh about 100 each
Old 05-08-2013, 01:55 AM   #8
Drew@Swift Motorworks
Past Site Sponsor
My Ride: Scooty Puff Jr
I can't fathom how you guys manage to live in a place with that dreadful season the call winter. Out here in California I've never even seen a remotely rusty spring on an e46.
Op can you pin point where you're rubbing? Is it in fact on the fender? It could be rubbing on something like the stud for the bumper clips. Iirc there are slight differences in the left and right wheel wells
Drew@Swift Motorworks is offline   Reply With Quote
