///M3 Forum
Old 05-02-2013, 08:05 AM   #1
sogood
My Ride: 95 S/C M3, 01 M3
E46 M3 Complete Rear End Overhaul
edit
sogood is offline   Reply With Quote
Old 05-03-2013, 09:08 AM   #2
sogood
bump
Old 05-05-2013, 01:02 AM   #3
PITT M3 RR
My Ride: E46 M3
Im using AKG everything in the rear and I love it. I dont have the mason bar, but I made my own so I have pretty much what you're going to end up with.
As far as being in there, While the Rear trailing arms are out, you can dig out the ebrakes from the hub preventatively as its almost a sure thing that theyre stuck in there. Other than that it sounds like you have it covered. Change diff fluid while its out with the output shaft seals and also you can get the ECS halfshaft boot kits and rebuild/pack the halfshafts. Thats a pretty easy job.
UUC SSK / AFE STG1 Intake / AKG Red Motor mounts / AKG Red Tranny mounts / AKG Red Subframe bushings / AKG Red Differential bushings / AKG Red RTABS / TMS Subframe reinforcement / Custom in trunk subframe structural brace / Bilstein PSS10's / Ground control camber plates / Turner RSM
PITT M3 RR is offline   Reply With Quote
Old 05-05-2013, 02:06 AM   #4
Andy2108
My Ride: SpecE46 & E46 M3
consider doing some drive shaft / csb maintenance too.
reinforce your subframe. reinforce your rtabs.
AKG makes good poly bushings in different harnesses.
If you're serious about tracking many times a year for a few years then go with semi solid/derlin/plastic/whateveryouwanttocall it. After a few years of properly hard use any poly bushings will be on their way out again. I wouldn't go with metal bushings/mounts unless its a racecar.
De gustibus non est disputandum.
Old 05-05-2013, 02:08 AM   #5
Andy2108
I am quite interested in buying a mason bar too. Would you mind taking a picture of the part that mounts to the shock tower? I might have some weird fitment issues with my car if the bar is too high.
Old 05-09-2013, 09:50 AM   #6
sogoos
My Ride: 95 M3, 01 M3
Sure, I'll try to post some pictures today on lunch. (I work at a shop)
Thanks for the input guys, definitely going to look into AKG - seems like everyone has nothing but good things to say about them.
PITT M3 RR - you have any more pictures of your rear bar?
sogoos is offline   Reply With Quote
Old 05-09-2013, 02:02 PM   #7
PITT M3 RR
My Ride: E46 M3
http://forum.e46fanatics.com/showthread.php?t=965897
Its all in there, pretty elementary stuff once its all straight.
Old 05-12-2013, 07:16 PM   #8
Eisenheim
My Ride: 2002 PY E46 M3
I feel for ya, bud. I too recently had the Sub-frame fail in mine. I had it repaired, reinforced with the TMS kit, and then had a brace built in the back, taking ideas from PITT and another guy. A long with that massive amount of work, I had the diff, sub frame bushing and RTABs done while it was in the shop.
Here's my thread, http://forum.e46fanatics.com/showthread.php?t=965528
Eisenheim is offline   Reply With Quote
Old 05-12-2013, 07:34 PM   #9
Eisenheim
here's the other design I took from. Notice how the brace is in constant contact with the car. http://forum.e46fanatics.com/showthread.php?t=909256
