Coilover install...What else should I replace while this is done? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
///M3 Forum
Old 04-30-2013, 08:07 PM   #1
nyredeye21
My Ride: 2003 E46 M3
So i have a 2003 M3 convertible and i bought some ST coilovers because my original suspension is shot. I live in NYC and daily drive this car.
Did some research and others recommended the following:
Front Strut Mounts
Front reinforcement plates
Rear Shock mounts
Rear reinforment plates
I was wondering if there is anything Im missing and what brand of parts did you guys use and your reviews.
I will post pics later...(Car currently has Tein S Tech lowering springs and stock shocks)
Thanks for the input.
nyredeye21 is offline   Reply With Quote
Old 04-30-2013, 10:46 PM   #2
shell_guy
My Ride: 2002 M3
I would replace sway bar links and control arm bushings while your in there.
shell_guy is offline   Reply With Quote
Old 04-30-2013, 11:18 PM   #3
z00
Banned User
My Ride: E46 M3 Manual
I replaced RTABS and FCABS when I put KW coilovers.
z00 is offline   Reply With Quote
Old 05-01-2013, 06:04 AM   #4
nyredeye21
Thanks for that. The st cool overs came with new front swaybar links so I will replace that during install.
I have already replaced both fcabs and rtabs with powerflex bushings. The rtabs haven't given me a problem in two years. I just installed the fcabs a little over a month ago and the passenger side keeps riding up the control arm. Don't recommend powerflex fcabs from my personal experience. Seems many others have had that problem as well
Old 05-01-2013, 06:05 AM   #5
nyredeye21
Anyone have suggestions as to what type of front strut mounts and rear shock mounts i should get
Old 05-01-2013, 02:24 PM   #6
nyredeye21
Bump
Old 05-01-2013, 02:54 PM   #7
shell_guy
My Ride: 2002 M3
I believe Rogue makes a set.
Old 05-01-2013, 02:57 PM   #8
nyredeye21
I found a few different rear shock mounts but I can only find OEM front strut mounts. Anyone know of any other options?
Old 05-01-2013, 04:47 PM   #9
Bigo1087
My Ride: 2006 M3 ZCP
I'm pretty sure theres only OEM Mounts and then Camber Plates, which you don't want if your DD it in NY, trust me.
2006 IB ZCP. TCKline S/A, Vorshlag Camber Plates, BMW SSK, H&R Front Swaybar, Intrvaee II, HID Fogs, OEM ZCP Wheels 245/275.
Bigo1087 is offline   Reply With Quote
Old 05-01-2013, 04:51 PM   #10
nyredeye21
That's what I thought. Thanks.
Old 05-01-2013, 04:52 PM   #11
nyredeye21
Upon inspection of the coil overs I noticed that the shocks are easily compressed by hand. Anyone know if this is normal?
Old 05-01-2013, 08:21 PM   #12
braaang
My Ride: E46 M3
shocks should be easily compressed by hand. how quickly can you compress them?
braaang is offline   Reply With Quote
Old 05-01-2013, 09:12 PM   #13
nyredeye21
They compress slowly. Maybe in excess of 10-15 seconds for full compression.
I just bought the rogue RSM that come with all hardware and z3 reinforcement plates already modified to fit convertibles. I also bought front strut mounts and all new bolts. Anything I'm missing?
Old 05-01-2013, 09:27 PM   #14
z00
Banned User
In case you don't know, ST coilovers will rust if you drive them in winter. Hopefully you garage your car in winter. If you drive in winter you should have gone with KW as they're made of stainless steel (does not rust with winter and salt).
Old 05-02-2013, 07:11 PM   #15
nyredeye21
As I understand it the KW's don't rust and come with an unlimited warranty. The ST's are rust resistant but not rust proof and they have a 5 year warranty which is why I choose these over Megan racing and BC coilovers (1 yr warranty each)
I am planning on selling this car very soon and getting another M3 hardtop. The next owner can do what he wants.
Old 05-06-2013, 08:59 AM   #16
nyredeye21
I bought OEM front mounts and rogue rear mounts.
Old 05-06-2013, 04:47 PM   #17
the fly
My Ride: '95 m3, '03 m3
what he said. these bushings go bad often...
the fly is offline   Reply With Quote
