E46 Convertible
Old 05-03-2013, 03:33 PM   #1
socalragtop
My Ride: 2001 330Ci
Question Still need the AC
2001 330ci ragtop... My AC blew freezing forever suddenly two days ago nothing. I get the AC light and I see the fan indicator go up but no blowing. I check that the compressor goes on and off from the switch and it does. I've read here about relays and fuses but can't seem to find what I need for this. Fuse 28 is also ok. Any suggestions or maybe a link to a post I missed? Thanks to all.
socalragtop is offline   Reply With Quote
Old 05-03-2013, 05:33 PM   #2
bigguy
My Ride: 2001 330ci vert
could that be the final stage resistor? someone chime in if I'm wrong.
bigguy is offline   Reply With Quote
Old 05-04-2013, 12:52 PM   #3
E46DrEaMeR
My Ride: 2004 330ci
thats what mine did when the fsr went
Its a ragtop thing! you wouldn't understand
E46DrEaMeR is offline   Reply With Quote
Old 05-04-2013, 07:41 PM   #4
socalragtop
My Ride: 2001 330Ci
Ordered one it will be here on tuesday. we'll see
Old 05-20-2013, 06:41 PM   #5
socalragtop
My Ride: 2001 330Ci
Fixed and working perfectly again. FSR was pretty easy to change. Thanks to all.
Old 05-27-2013, 07:10 PM   #6
XKR
My Ride: 2001 M3 Convertible
My FSR only seems to act up when it's over 110 degrease and when I need AC the most. Is the FSR behind the glovebox?
XKR is offline   Reply With Quote
Old 05-30-2013, 03:59 PM   #7
Texas Joe
My Ride: 330 ci
A/C Resistor
Is this pretty easy to change????? Mine went out to and I live in Texas!
Texas Joe is offline   Reply With Quote
Old 05-30-2013, 04:36 PM   #8
socalragtop
My Ride: 2001 330Ci
The glovebox needs to be removed but technically it's behind the center console. It's relatively easy to change just kinda tight getting in there. I found a video on you tube that gives a walk through.
Old 05-30-2013, 05:23 PM   #9
Texas Joe
My Ride: 330 ci
Fsr
Thanks, maybe my weekend job.....can I get the part at the local parts store?
Old 05-30-2013, 09:47 PM   #10
socalragtop
My Ride: 2001 330Ci
I didn't find the part at any of my local stores here in ca. I ordered it from ebay for $65 oem. Took maybe an hour to fix when I followed the video. I had to apply a good amount of pressure pulling out the side of the console to get the vent tube out. And putting it back was a pita until I realized if I lined up the bottom tube the top would fit right in.
Old 05-31-2013, 01:45 AM   #11
Texas Joe
My Ride: 330 ci
Fsr
Cool. Do I need any special tools that you make think of? Thanks for the info.
