Sponsored by The Tire Rack
Old 05-04-2013, 04:42 PM   #1
Eurogasm
My Ride: 2000 328Ci
Question Help!! New wheels wont fit!
Hey guys, I just bought a new set of Miro 279 lm replicas. They're 5x120 and I made sure the offsets worked but when I just went to put them on I found that the hubs are exactly the same size (line up flush instead of fitting over) and they won't clear. Because of this is looks like the lugs all need to be slightly further out as well. Is there anything i can do to make these fit? Adapters or milling the center the millimeter to clear? I'm devasted these aren't fitting
Eurogasm is offline   Reply With Quote
Old 05-04-2013, 05:28 PM   #2
Eurogasm
My Ride: 2000 328Ci
Anyone have any advice?
Old 05-04-2013, 09:41 PM   #3
lamsv
My Ride: 2001 325iT
You just answered your own question. Mill the hub, or spacers/adapters the have the correct hub diameter.
lamsv: 2001 HELLROT on BLACK 325iT
lamsv is offline   Reply With Quote
Old 05-05-2013, 01:55 PM   #4
Minnoe07
My Ride: 2004 BMW 330Ci
Sounds like you got a set of wheels with incorrect center bore. Return it and specify what vehicle you have and get a different set with correct center bore.
2004 330Ci 6 Speed; UUC Sway Bars; Powerflex RTAB's and FCAB's; KW V2 Coilovers; 3.38 OS Giken LSD
Z4 Finned Diff Cover; Headers; M-Tech II Rear Bumper and CF Diffusor; CF Trunk; CSL Front Bumper
M3 CF Hood; DICE I-Pod Kit; JTD Rear Shock Mounts; UUC Front Strut Bar; O2 Simulators
ESS TS2 Twin Screw Supercharger
Minnoe07 is offline   Reply With Quote
Old 05-05-2013, 11:32 PM   #5
TrippinBimmer
My Ride: Just Fast!
take pics can explain alot. also wire brush the hub too...
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 05-06-2013, 11:12 AM   #6
jkalro
My Ride: BMW 330ci
Return these rims and get the my two 19 inch x 10 wide Linea Corse LC818 rims and tires I have for sale. check the NJ/NY/CT forums.
2004 BMW 300ci Convertible with sports package
jkalro is offline   Reply With Quote
Old 05-06-2013, 01:33 PM   #7
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Assuming these are 72.6mm, you probably just need to clean your hub. Take a wire brush to it and clean off any rust that may have accumulated.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
