Old 05-04-2013, 09:55 PM   #1
DarkSyde330ci
My Ride: COUPE
new guibo and csb still a slight rumble strip noise
I replaced center support and guibo today and although the rumble strip sound is gone while at mild/normal throttle... it still chimes in at full throttle launches.
I set csb preload to the exact spot of the old csb I highly doubt It was 4-6mm though like I've been looking up. Tomorrow ill set it at 4-6mm like it says but do you guys think it'd really make that noise stop or is it subframe bushings or trailing arm bushings maybe?
This sucks
DarkSyde330ci
DarkSyde330ci is offline   Reply With Quote
Old 05-04-2013, 10:04 PM   #2
Snik
Snik's Avatar
My Ride: IR M3 Vert.
have you changed the wheel bearings?
sometimes a bad front one can sound like the rear, and when the rears are bad, they just never shut up.
Do you ride a sportbike?
Snik is online now   Reply With Quote
Old 05-04-2013, 10:18 PM   #3
DarkSyde330ci
My Ride: COUPE
I def have some bad wheel bearings but this def sounds like right under Trans tunnel like its the csb
DarkSyde330ci
Old 05-04-2013, 10:26 PM   #4
Snik
Snik's Avatar
its probably the wheel bearing then....
Old 05-04-2013, 10:40 PM   #5
DarkSyde330ci
My Ride: COUPE
Wheel bearing causes driveshaft to mak the rumple strip sound? Those are a lot easier to replace if so lol
DarkSyde330ci
Old 05-04-2013, 11:01 PM   #6
Snik
Snik's Avatar
how do u know its the drive shaft?
when BMW wheel bearing go bad they sometimes sound like a million other things.. but generally any rumble strip sound you hear it typically the bearings. a bad CSB usually results in increased drivetrain lash and only makes noise when drive hard.
Old 05-05-2013, 07:38 PM   #7
DarkSyde330ci
My Ride: COUPE
So.... new guibo, new center support bearing (old one was destroyed), u joint felt perfect, I marked everything perfectly and regreased the ball bearing section that attaches to the diff. I preloaded the csb like im supposed to yet I still get a slight rumble strip noise on Trans tunnel like its still a bad csb. The sound is definitely not as loud as before though but still there.
DarkSyde330ci
Old 05-11-2013, 01:53 AM   #8
Wielandgeorg
My Ride: 04 325ci
I'm having a similar issue after changing all the guibo and Csb and diff mounts my driveshaft still shudders around 20mph and shakes center console
04 325ci
I tried and tried but haven't found a solution unjoints feel good.
Let me know what happened with your problem maybe we can help each other.
Wielandgeorg is offline   Reply With Quote
Old 05-11-2013, 09:06 AM   #9
DarkSyde330ci
My Ride: COUPE
What I'm trying next is throwing a ratchet strap around Trans and Trans crossmemer and tightening it up and see if it stops... I'm thinking its the Trans mounts... ill report after a few
Or worse case scenario its damaged rear subframe mounts
DarkSyde330ci
Old 09-24-2013, 10:50 AM   #10
davidedwardse46
My Ride: 323i e46, 1988 535is
Has anyone narrowed this down i have had the same issue I have replaced motor mounts, guibo, csb, i was thinking it was rear diff suport bushing it only happens at hard acceleration around 20-25 mph. Thanks in advance
davidedwardse46 is offline   Reply With Quote
Old 09-24-2013, 12:25 PM   #11
generic
My Ride: 2002 BMW 330ci
Re: new guibo and csb still a slight rumble strip noise
Having the same problem around 10-20 mph with very mild acceleration center console feels like someone is under there hitting it with a hammer has me scared im going to lose my driveshaft at every light. Bought a guibo and CSB but yet to install exhaust bolts are welded so can't get past step one
Sent from my DROID BIONIC using BimmerApp mobile app
generic is offline   Reply With Quote
Old 09-24-2013, 03:12 PM   #12
Phoenix330ci
My Ride: 04 330Ci Convertible
Add another 04 330ci to the mix. Been told on here by others it is the CSB and guibo but have not had the chance to even get under the car and investigate. Originally I though it was suspension related (which I needed a new one anyways) so I replaced all four corners shocks and struts and all parts associated with them, like the mounting plates, rubbers, bolts, washers. Still does it so I'm saying not any of those parts.
Noise happens just like everyone else says at 10-25 mph but more when the rpms are up to 2500-3000 in first and second gear. If you were to get the rumbling up really good in 1st and shift to second (automatic) around 3000 it doesn't happen in 2nd then.
Would like to know exactly what the problem is before I shovel a tone of cash at it. I have also been thinking trailing arm bushings or sub frame bushings. I replaced one rear and two from sub frame bushings awhile back. From what I can tell the rear one still looks good.
Phoenix330ci is offline   Reply With Quote
Old 09-24-2013, 05:18 PM   #13
TerraPhantm
My Ride: M3 & ZHP
The driveshaft CV joint could be bad
Old 09-25-2013, 06:23 PM   #14
Tangent_
My Ride: '01 330i, '11 Z435i
+1
I had my CSB fail, first with the rumble strip description mentioned earlier, progressing to a flat-out banging under acceleration. A new guibo and CSB just reset the banging to the rumble strip sound. One new driveshaft later, all the noise and vibration was gone. Between this one and the failed driveshaft on my E30, it seems that more often than not the CSB doesn't fail on its own, it's just a symptom of a failing driveshaft u-joint/cv joint.
http://forum.e46fanatics.com/signaturepics/sigpic70081_4.gif
Tangent_ is offline   Reply With Quote
Old 09-25-2013, 08:53 PM   #15
davidedwardse46
Yeah that's what I am beginning to believe I know you joints are good I thought the drive shaft was fine when I took apart for csb, after I changed guibo and csb a month ago it stopped for a few days then started again but I am changing rear diff bushings and then I guess a new drive shaft poor me
Old 09-29-2016, 02:59 PM   #16
XbadrolemodelX
Same issue with mine. Ever solved?
XbadrolemodelX is offline   Reply With Quote
Old 12-28-2016, 12:25 AM   #17
shaunformel
My Ride: 330Ci
2001 330Ci with rumble noise happens when accelerating from a stop turning left- replaced guibo, csb and right side drive axle, has improved some, now it will go away if i stay in it, where it used to get worse and i had to slow down to make it stop, now it vibrates about 3-4 time and quits but it's still there. Drive shaft seemed tight- i checked it when i pulled it to change the csb. Could it be in the differential itself? I changed the drive axle first, thought maybe it was slipping. Called the mechanic and he said he thought it was a wheel bearing??? I spun the wheels when i replaced the drive axle and didn't hear anything andit was tight-it doesn't sound like a bearing- it's only there when i accelerate from a stop turning to the right.
The rumble sound didn't take long to get worse, maybe a month or two commuting 100mi. to work 4 days a week.
could it be the shocks or differential mount.
It got better when i changed the guibo and the csb- logically would you think the rumble is from the driveshaft????? what makes it only happen on accelerating from a stop turning left????
shaunformel is offline   Reply With Quote
