Sponsored by BAVSOUND
Old 07-16-2003, 04:09 AM   #1
daz
My Ride: 2003 Bmw Coupe 330ci
Send a message via AIM to daz
Relay
Relay
Hello have a question regarding connecting a relay. I have a output wire from my non-OEM alarm that is negative and activates the parking light when alarm is activated-1 flash, de-activated-2 flashes, and alarm tripped constant flashing.
Where on my BMW 330ci 2003 would I connect the relay to. I looked on the drivers side where the light switch is and went inside the dash but looks like the switch is attached to the LCM (light Control Modual) Where do I need to tap into? If the wire out put from my alarm is negative do i actually need a relay.
See pic of relay..
Any suggestions???
daz is offline   Reply With Quote
Old 07-16-2003, 10:01 AM   #2
daz
Anyone has to have some idea's...
Old 07-16-2003, 08:36 PM   #3
JACOB NJ
My Ride: 00 540 sport
Send a message via AIM to JACOB NJ
ok
so your trying to make the lights flash with that output from you non oem alarm? if not what is it that you ultimatly want that wire to do?
JACOB NJ is offline   Reply With Quote
Old 07-16-2003, 09:08 PM   #4
daz
Re: ok
Correct,
Old 07-17-2003, 08:03 PM   #5
JACOB NJ
ok what you have to do is. take the outpu tout of the alarm and put it to the pin numbered 85 assuming the output is negative. then give the 86 pin a constant 12v . now for the trickey part. take out the LCM take the front off of it and you will see a ribbon cable holding the two pieces together. With the switch facing towards you, you need to interrupt the fourth wire from the left with the relay pins 30 and 87a . pin 30 going to the switch side of the LCM. got it?
so pin 85 output from alarm
pin 85 12v
pin 30 to switch side of LCM
pin 87a LCM side.
what is going to happen is when you hit the alarm key the relay will energize and disconnect the two wires turning on the lights and when it not touched it will act like is not even there. take a pic of that relay wires facing camera just the way its laying there now.
Old 07-18-2003, 11:06 AM   #6
daz
Here you go...
Front pic of relay!
Name:	disney 2003 007.jpg
Old 07-18-2003, 11:07 AM   #7
daz
more relay
more
Name:	disney 2003 013.jpg
Old 07-18-2003, 07:23 PM   #8
JACOB NJ
do it wires facing the camera. so i can tell you what wires go to what.. lay it down on the desk with the metal tab down on the desk. then snap a pic of the wire side ( bottom of the relay)
Old 07-18-2003, 08:40 PM   #9
daz
OK
Old 07-18-2003, 08:47 PM   #10
daz
Lightbulb Here is the pic..
Here is the pic of the relay....................................................... ................Thanks for your help..
Old 07-18-2003, 08:47 PM   #11
daz
With flash
relay
Old 07-18-2003, 08:56 PM   #12
JACOB NJ
hmm
metal tab on top? or bottom in that pic? im guessing on top right>?
Old 07-18-2003, 09:04 PM   #13
daz
metal tap top
Old 07-18-2003, 09:11 PM   #14
JACOB NJ
ok yellow 12v
center red pin LCm side of the wire your going to cut.
bottom red wire to Switch side of the wire you going to cut
and the blue is your input - gets connected to the parking light output of of the alarm.
Old 07-19-2003, 12:46 PM   #15
daz
JACOB NJ,
Thanks a million for taking the time much apreciated........!!
Old 07-19-2003, 05:29 PM   #16
JACOB NJ
Originally posted by daz
JACOB NJ,
no problem.. did you get it done?
Old 07-19-2003, 08:21 PM   #17
daz
Not yet.. Yesterday I installed Components up front, mid in rear deck, Sub in trunks, two amps, and all the wiring.
Going to get to the the relay. On Monday.. Japan has a three day weekend.. Got to take the wife out before she start complaining about the time I spend on the car...With all the mods going into the car feels like I am spending $1000 a week on stuff.
The only thing I need now is the Shark injector.. Then I am done...
