Old 05-05-2013, 01:09 PM   #1
SK330ci
My Ride: 02 330ci w/ 3 Pedals
Oil Pressure Gauge / PSI At Idle
For those of you that use a oil pressure gauge on your Non-M E46, what oil pressure are you seeing at idle?
Mods: Header, CAI, Shark, Koni Sport Struts, Rob43 9 Way Shocks, Big Sway Bar, Special Lowering Springs, 3.38 Diff, PFC Z-Pads, 75 Shot Of N20
E46 M3's are just tasty snacks i eat for lunch.
SK330ci is offline   Reply With Quote
Old 05-07-2013, 04:55 PM   #2
shanneba
My Ride: 2003 330Ci
I usually see around 14-16 psi at idle with the engine completely warmed up. (closer to 20 when I was running Red Line 5w-40)
Have seen as low as 10 psi after a track session at Road Atlanta where oil temps hit about 260 F.
Join BMWCCA
Old 05-11-2013, 02:44 PM   #3
SK330ci
Thank you, ........anyone else ?
Old 05-15-2013, 02:59 PM   #4
E30Gelardi
My Ride: E30
Not sure what the factory pressure switch is set at, but after my last track day at idle the oil light would flicker. I'm guessing that could be as low as 12psi.
E30Gelardi is offline   Reply With Quote
Old 05-15-2013, 03:00 PM   #5
E30Gelardi
My Ride: E30
On my ZHP that is
