E46 Convertible
Old 05-06-2013, 11:18 AM   #1
BobInPa
My Ride: 03 330Cic, Passat SW
Lube Rear Window Mechanism?
My driver's side rear window has started to squeak when raising or lowering it. This occurs whether the top is up or down.
Is there any way to lube the mechanism without removing any body panels, which is beyond my skill level? If so how and what lubricant?
Thanks,
Bob
BobInPa is offline   Reply With Quote
Old 05-06-2013, 11:31 AM   #2
taylor192
My Ride: 2003.5 M3
Thanks,
Bob
If 5 screws are beyond your skill level get a shop to look at it. All that holds on the rear interior panels are 5 screws on either side, and there are a couple great DIYs with pictures showing how to remove them.
Old 05-06-2013, 12:34 PM   #3
BobInPa
As Emily Litella always said "Never mind".
I washed the rear window and the rubber around it and the squeak is gone. Probably pollen related.
Thanks anyway.
Old 05-11-2013, 04:58 AM   #4
chrisv.e46
My Ride: 330ci Convertible
Thanks,
Bob
Had the same problem, I used silicon spray and it worked a treat.
chrisv.e46 is offline   Reply With Quote
Old 05-11-2013, 06:49 AM   #5
sgoetz628
My Ride: 2002 330 CiC
You used the silicon spray on what?
I love my car as much today as the day I bought it
sgoetz628 is offline   Reply With Quote
Old 05-11-2013, 10:43 AM   #6
cityjohn
My Ride: 2001 M3
Same here. I just cleaned the rubber strip and treated with Aerospace 303. Now and then the squeak returns; I just repeat the procedure.
If you can get your hands on the elusive gummipflege you could try that.
cityjohn is offline   Reply With Quote
Old 05-11-2013, 07:35 PM   #7
chrisv.e46
Thanks anyway.
On the rubber seals on the glass and trims
