Sponsored by BimmerWorld
Old 05-06-2013, 07:58 PM   #1
330idriver
My Ride: 330i
Thumbs Up Rebedding Brakes
I am a believer!
I had a high speed brake shudder issue that was getting worse.
I figured I had a warped rotor as I had always been told. I had my first "warped rotor" in the 80's on my 72 Chevy Vega.
Based on the reccomendations from this forum I went through the bedding process this morning before work on my 3 year old Akebono ceramic pads and Brembo blanks. After 8 cycles from 10mph to 60 then rapidly back to 10 then immediately onto the route 78 on ramp to work without stopping ( perfectly timed and rather fun). I was still feeling the shutter a little bit (albeit much less) after the last rep, but after cool down the shutter is now gone. Yea!
Thank you fanatics. I guess you can teach an old dog new tricks.
Sport Pckg,Orient Blue,Grey Leather
OEM M3 front strut brace
Dinan rear strut brace
Bilstein Sport Struts & Shocks (B8)
Eibach Pro Kit Springs (B12 Kit)
Diesel air ducts
Bel remote Radar & Laser detector
IceLink Ipod adapter
Meyle Platinum Rotors
Hawk HPS 5.0B Brake Pads
K&N filter
330idriver is offline   Reply With Quote
Old 05-07-2013, 11:01 AM   #2
lszlszx
My Ride: 1.8T, XC70
Worn control arm bushings can cause that, too.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
