Old 05-06-2013, 08:20 PM   #1
mdrobnak
My Ride: 04 330i SMG TT STG1
330i Stock Clutch Specs
Anyone know what the 2004/2005 330i Stock clutches can hold tq wise?
I've tried looking around but I'm unable to find an actual number. Trying to decide to do with my car and this plays a fairly important role.
Thanks.
-Matt
mdrobnak is offline   Reply With Quote
Old 12-31-2013, 04:45 AM   #2
Davew
My Ride: 2004 330ci Msport
Hi Matt,
older post I know, but I'm in a unique situation where I can answer this to a degree, plus, car is also 6 speed ssg. At 298whp, with ts2+ running with vacuum issues (5 psi boost), with less than two year old clutch ( oem ), no issue. At 310whp, with ts2+ running well, squeal from clutch in sports mode at 3000rpm+ loaded shifts. I know you are much more advanced than this now, so hopefully this info will help someone else down the track.
Hp figures are from a dyno dynamics dyno. I believe, there is a 13% difference between figures from a dyno jet to dyno dynamics dyno.
My dyno figures are posted in the dyno section of the forum.
If dyno before and after repair for torque figures are required, pm me
Davew is offline   Reply With Quote
