Cracked lens repair project - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 05-07-2013, 08:12 AM   #1
aristotle
My Ride: 330ci
I have a facelift coupe with OEM bi-Xenons. While repairing a headlamp washer leak recently, I noticed that a headlight lens is cracked. The crack starts underneath from where the clear lens meets the black housing, and extends forwards. Looks like a manufacturing defect, as the width and displacement of the two parts along the crack line suggest that they have been married unwillingly under some force.
There's no replacement lens offered either by BWM, or OEM suppliers like Magneti Marelli or Hella for this particular assembly. I've looked into the DEPO assemblies as possible replacements, but the OEM bulbs and ballast are not compatible. Replacement assemblies are ~$750 each, and I don't want someone else's used and possibly chipped (or cracked) lenses.
Long story short, the crack is not visible on the front of the lens yet, so I've decided that I've nothing to lose by attempting a repair. Did some research, and have determined that the lenses are made from a polycarbonate called Lexan, and that the best adhesive would therefore be an acrylic like Weld-on 16. I drilled tiny a hole just ahead of the crack to try to stop it extending any further, then glued it up. The bond looks strong, so I guess only time will tell now if this has worked...
aristotle is offline   Reply With Quote
Old 05-11-2013, 05:27 PM   #2
sillieidiot
My Ride: '06 AW 330ci
that doesn't look like a manufacturing defect to me. but i guess your solution works. did you test it at all? like for water
