///M3 Forum
Old 05-07-2013, 05:37 PM   #1
PiL
My Ride: 2006 | M3 | CBM
Those running Koni Sports with lowering springs
I will be rolling on TEIN S TECH springs. For daily driving/street, where should the Koni struts/shocks be set to? I have read one post which indicated 1/4 turn up from full soft. Would like to get the rears set correctly during instal since I understand that they need to be removed. Also, how are they set new/from the box? Thanks!
2006 | M3 | CBM | 6MT | TEIN S Tech & Koni Sport | BMS Spacers 15mmF/10mmR
PiL is offline   Reply With Quote
Old 05-07-2013, 06:12 PM   #2
taylor192
My Ride: 2003.5 M3
1 turn from soft. The adjustment range is 2.5 turns, and you don't want to start off completely soft and have no adjustment range left.
YMMV since what I like for DD might not be what you like.
