Sponsored by The Tire Rack
Old 05-07-2013, 07:35 PM   #1
earlgrey1920
My Ride: 2003 325i Sport Pkg
Understanding wheel offset; will these wheels fit?
Let me see if I can answer my own question. I have a 2003 325i with Sport Package (17" wheel option) and want to purchase a set of wheels for my summer tires (which are also 225/45/17). The question is whether the new wheels will fit.
My stock wheels have a 47mm offset. The wheels I would like to purchase have a 40mm offset. (The bolt pattern, bore, and size are the same as my stock wheels.)
My understanding is that a lower offset of 40mm will make the wheel extend the outer position by 7mm (closer to the outside of the car) as well as provide a bit more clearance on the inside.
In short, the wheels should fit (and perhaps also look better in terms of where they sit).
I'd appreciate your feedback.
Many thanks!
earlgrey1920 is offline   Reply With Quote
Old 05-08-2013, 12:04 PM   #2
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
If you're comparing a 17x8 ET47 to a 17x8 ET40, you are correct. No fitment issues.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 05-08-2013, 12:07 PM   #3
earlgrey1920
I am indeed comparing 17x8 ET47 to a 17x8 ET40. Thanks for the reply!
Old 05-08-2013, 12:56 PM   #4
VMRWheels
VMRWheels's Avatar
You're welcome!
Old 05-10-2013, 10:38 AM   #5
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
Originally Posted by vmrwheels View Post
if you're comparing a 17x8 et47 to a 17x8 et40, you are correct. No fitment issues.
+1
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
