Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Suspension and Braking
Springs, shocks, struts, coilovers, camber plates, sway bars, strut bars, suspension bushings, control arms, brake pads, big brake kits, etc.
Old 05-07-2013, 07:38 PM   #1
braymond141
My Ride: 96 M3, 02 M3, 01 M5
E46 M3 TC Kline S/A Coilover Kit w/TCK Camber Plates - $1300.00
I have for sale a complete TC Kline S/A coilover kit with around 35-40k miles on it, all CA used. Purchased in 2008, street use only. The reason the price is $1300 is because the driver side front strut is blown. There was nothing that caused it to blow, it just failed. I am not the original owner (however the kit was installed only ever on one car) so I cannot take advantage of any warranty. A new shock is $329.00 + shipping from TCK. So for around 1600ish you can have a full kit that is ready to go, plus the blown driver shock probably has some value for parts or maybe it can be rebuilt for cheaper.
Included;
Front S/A TCK Koni Struts
Front 500LB TCK Springs
Front Spring Perches, Adjusters, Collars, Nuts, and Spring Isolators
Front TCK Adjustable Caster/Camber Plates
Rear S/A Koni TCK Shocks
Rear 600LB TCK Springs
Rear Height Adjusters (I will include the bolts used to secure the adjuster to the control arm)
Rear TCK Shock Mounts and Nuts
Full setup - $1300.00 + Shipping (New this is $1776 + $495 w/ camber plates)
Call or Text; 949-500-8493
Located in 93644
As you can see all the parts are in super super clean condition. The only other thing to note is that one of the rear adjusters on the shocks, as will all Koni's ( ) doesn't always adjust. Set the adjustment outside the car as it will be easier to do then. It's finicky as most people note. Other shock adjuster works perfect (for now?).
Actual pics, everything shown is included, plus I have the adjustment wrenches too (not shown).
braymond141 is offline   Reply With Quote
Old 05-07-2013, 08:23 PM   #2
TrippinBimmer
My Ride: Just Fast!
man i want that 600lbs rear spring. I have some 500lbs if anyone wants to trade...
BTW: GLWS
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
Stock
NAwhp/NAwtq SAE Corrected
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
