///M3 Forum
Old 05-08-2013, 10:53 AM   #1
knappster69
My Ride: 2004 BMW E46 M3
Brake Fluid
Hey guys,
Wanted to ask if a specific brake fluid is required for E46 M3.
I see most people go with the ATE Super Blue or Gold. From my understanding, as long as the fluid is a DOT4, it should be acceptable.
Not trying to run cheap fluid but is it really necessary to run the ATE?
When I first bought the car I was unaware of how specific the oil must be and just wanted ask around if it applies to the brake fluid as well?
Thanks,
MAK
knappster69 is offline   Reply With Quote
Old 05-08-2013, 12:37 PM   #2
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Quality DOT 4 fluid is all the E46 M3 requires. ATE Super Blue and TYP200 are popular because of their raised boiling points, and going from Blue to 200 you get a clear change in colors when you refresh the system, helping insure a proper flush.
Personally I run Motul RBF 600 in my cars, it's another quality fluid with a very high boiling point.
Now if you're going to track your M3 I highly suggestion going to a fluid with an elevated boiling point over standard DOT 4 fluids, this will help prevent against boiling brake fluid at the track.
Old 05-08-2013, 04:08 PM   #3
knappster69
Right on! Good to know. I mean it is basically just a hydraulic fluid in a sealed system. Main concern was the seals if another "brand" was used.
Thanks!
