Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Suspension and Braking
Springs, shocks, struts, coilovers, camber plates, sway bars, strut bars, suspension bushings, control arms, brake pads, big brake kits, etc.
Old 05-08-2013, 05:16 PM   #1
Racer2B
My Ride: -
FS: JRZ RS Double Adjustable Non-reservoir: Front Right
JRZ RS Double Adjustable Non-reservoir (IT Legal) for E46 3 series Front Right. Shocks works fine (just used it at Pocono with no problems), but the shock body on the lower 4" where it slides into the spindle is ever so slightly tweaked. It did not affect performance, it just made the shock like 5mm closer to the tire, so I had a clearance issue with my wheel offset.
Looking for $500. This is just the Shock, 2 lower spring collars and upper spring perch. (picture coming shortly)
Thanks,
Steven
TrackPro Advisors - Currently Recruiting technical and Coaching Advisors. Are you a BMW technical expert or a professional driver coach? Apply Now.
Racer2B is offline   Reply With Quote
