///M3 Forum
Old 05-08-2013, 06:41 PM   #1
Jaypefelix
My Ride: 2004 m3
04 e46 bangs into gear
Hey guys I bought a 2004 e46 vert smg. When I'm at hi speeds it bangs into gear I was told the previous owner that I had to change the geebo mount which I never heard of it is there such a thing and where is it located. Thanks.
Jaypefelix is offline   Reply With Quote
Old 05-08-2013, 06:58 PM   #2
Jaypefelix
My Ride: 2004 m3
Thanks bro yeah it seems to only bang when I'm flooring it and its switching gears is that normal ?
Old 05-08-2013, 07:02 PM   #3
lsbmatt
My Ride: 2002 vert m3 lsb smg
I deleted that previous msg, I made a mistake.
I changed the RTABS and the FLEX Disk Guibo. Falling apart/cracked Guibo would make a harsh shift.
RTABS made the car squirrly, sliding all over.
Flex Disk "Guibo" is attached to the drive-train.
Flooring it and switching gears, and it banging into gear, is kinda normal, its called the "M3 buck" . Like a bucking bronco/horse.
My Guibo was falling apart, check yours. Floor it but let off the pedal a tad when switching gears, let it switch smooth then floor it again.
http://store.bimmerworld.com/guibo-flex-disc-p506.aspx
lsbmatt is offline   Reply With Quote
Old 05-08-2013, 07:04 PM   #4
Jaypefelix
My Ride: 2004 m3
Thanks bro I def wi.
