Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 05-09-2013, 01:31 AM   #1
monkeyjuice5150
My Ride: ///M3 droptop
Send a message via AIM to monkeyjuice5150
bathroom wall tiling.
Do you guys prefer tiling over plastered/painted walls to save time and cost, or do it right the 1st time. Knock out the drywalls and put up cement boards?
monkeyjuice5150 is offline   Reply With Quote
Old 05-09-2013, 02:44 AM   #2
GlockMan
GlockMan's Avatar
My Ride: Suburban LT 4x4
Wet areas need hardiboard, dry do not but i would do anyway.
I would also use Schluter-KERDI-BAND in the corners of the shower/tub.
JMO
!!! ROLL TIDE ROLL !!!
National Champs: 1925, 1926, 1930, 1934, 1941, 1961, 1964, 1965, 1973, 1978, 1979, 1992, 2009, 2011, 2012, 2015, 2017?
Ranting about Panny plasmas, Canon cameras, Glocks, BlueNile, and HDMI on a BMW board since 2005.
2016 Honda Accord Sedan V6 Touring (wife)
2007 Chevy Suburban LT 4x4 with Nav/Bose/DVD
1968 Ford Mustang with Polk/ADS (my first car)
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
GlockMan is offline   Reply With Quote
Old 05-12-2013, 02:32 AM   #3
Fisch330ciTopasBlau
Yes...I do think I hate you
Fisch330ciTopasBlau's Avatar
My Ride: A car.
I may do some glass tiles on the walls around my soaking tub and in the shower, don't know if I'd like the whole master bath to be tiled, too clinical looking maybe.
-8/21/2007 RIP Grandma
-pessimum genus inimicorum laudantes: flatterers are the worst type of enemies
Fisch330ciTopasBlau is offline   Reply With Quote
Old 05-17-2013, 12:18 AM   #4
monkeyjuice5150
I like having at least one wall being a smaller tile then the rest. Like those 1x1 inch tiles.
Also, check it out. I just demo both my bathrooms, and going to lay cement board next week. I have to finish taking out the drywall 1st.
While I was taking off the the tiles, there was chicken wires. When I do go install the tiles again, should I use chicken wires at all?
I did some research, and it says chicken wire would make it stronger if installed right. But then it is also prone to causing the grout and tiles to crack or even break over time. Because there may be air space between the wall and mortar caused by the wire.
Old 06-04-2013, 04:38 PM   #5
TnT817
My Ride: 01 330ci
No chicken wire. It makes things a huge PITA. If this is your first time doing tile a wall shouldn't be your first crack at it. Tiling is easy once you've done it enough but walls are quite a but harder than floors. Just a heads up because tile can be expensive and you don't want to f**k up and loose money.
TnT817 is offline   Reply With Quote
Old 06-04-2013, 04:44 PM   #6
Brevik
My Ride: Tiag M3
I would use hardboard or cement board if it is a wet location. As mentioned above a wall might be a tough place to learn how to tile, but certainly not impossible to get right.
Check youtube for some good diys.
Brevik is offline   Reply With Quote
