Old 06-14-2013, 08:30 PM   #21
thesull
My Ride: e46
Driving around town is fine. Just 'babying' it... but recently I wanted to lay into it some... thats when I noticed it wants to act up. It sputters like it is choking. I observed that the air fuel will drop to 12/11 and little lower. It was over boosting at one point not ridiculously but a bit more than normal when I was getting into it.... It acts this way when it starts to boost heavy it will act like it is coughing per-say. I have read a lot of information lately and just cannot put my finger on the issue.
thesull is offline   Reply With Quote
Old 06-14-2013, 08:34 PM   #22
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
HPF E46 turbo Grassroots Support
Have u looked at ur plugs? Gap, condition etc
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is online now   Reply With Quote
Old 06-14-2013, 08:38 PM   #23
thesull
My Ride: e46
Ordered.
IXU27 5337
Old 06-14-2013, 10:52 PM   #24
being3
Modded ///Member
being3's Avatar
Ordered.
IXU27 5337
Had the same problem all of a sudden at about 12000 km. Gap for my stage 2.5 is 22 thou, if poor idle, increase by 1 thousandths till its good.
Old 06-20-2013, 12:24 AM   #25
Jealous World
My Ride: 2001 BMW ///M3
I'm having the same exact issue with my stage 2 please if you find out the problem please let me know! I've been stressing in this issue for to long :/
Jealous World is offline   Reply With Quote
Old 06-20-2013, 04:32 PM   #26
being3
Modded ///Member
being3's Avatar
Look at ur plug gaps first....
Old 06-20-2013, 07:08 PM   #27
Jealous World
I already swapped out my plugs the ones that came out seemed just fine..
Then put new ones in with a bigger gap.. And it ran a little better then went back to **** within 2days..
Old 06-20-2013, 07:38 PM   #28
being3
Modded ///Member
being3's Avatar
Not sure what stage kit u have. But smaller gap is for high Boost/ rpm and wider gap to get better idle. What gap r u at?
Old 06-20-2013, 08:42 PM   #29
Jealous World
I was at 22 and was misfiring very consistently l.. The new ones are 26 I have a stage 2
Old 06-20-2013, 11:51 PM   #30
02black330ci
My Ride: spaceship
Have you checked your coil packs?
02black330ci is offline   Reply With Quote
Old 06-20-2013, 11:53 PM   #31
being3
Modded ///Member
being3's Avatar
Could be a number of things.... Coil gone bad... Vanos selinoid possibly... Boost leak....It's hard with the kit as u cannot get the codes because r kit throws so many... U could do a obdIi scan and see what u get..see if any codes r out of the ordinary with r kit.... Bad sensor is possible.... Is ur Aem u locked ? If so download the logs
Old 06-21-2013, 12:01 AM   #32
John Reed
My Ride: AE86
Where are you located in TN?
John Reed is offline   Reply With Quote
Old 06-21-2013, 06:29 PM   #33
thesull
My Ride: e46
Nashville.
Why do you ask?
Old 06-21-2013, 06:31 PM   #34
John Reed
My Ride: AE86
Nashville.
Why do you ask?
Well I do a lot of travel tuning but I also have a shop in TN that I do quite a bit of remote tuning/work with, but they are up in Knoxville which if I remember right is about 4 hours from you so probably not the most convenient.
Old 06-22-2013, 03:25 PM   #35
thesull
My Ride: e46
Plugs and multiple boxes of parts going on the car this weekend. Will report back tomorrow with updates.
Old 06-23-2013, 10:15 PM   #36
thesull
My Ride: e46
Plugs helped a huge amount.
My gaps were all over the place on the old ones.
However I believe I found my issue to be a break in the harness. The plug that is for the wastegate had a wire that backed out...
The plug itself reads 47 PED? It is a blue connector that is used all over the harness. I went to the auto parts store because it looks like a headlight plug... yet no luck.
Any thoughts on where to find a replacement plug?
Old 06-24-2013, 01:58 AM   #37
John Reed
My Ride: AE86
Put up a picture of the connector, I likely have them but don't recall what HPF used for those.
Old 06-26-2013, 03:04 PM   #38
being3
Modded ///Member
being3's Avatar
Old 06-26-2013, 08:57 PM   #39
thesull
My Ride: e46
Thanks man for posting!
Here is his link:
http://www.flickr.com/photos/being3/with/9146448108/
The wire backed out of mine and my waste gate is staying open... bummer.
Old 06-26-2013, 09:11 PM   #40
being3
Modded ///Member
being3's Avatar
